> Fitting Momo steering wheel
cal914
post Mar 3 2017, 02:52 PM
Im looking to fit a Momo steering to my 1971 914 but i can't find anywhere that sells the right Hub,they either sell Hubs for 914-6 or for a 72-76 car
Any ideas where i might buy one
Thanks Brian
turnaround89
post Mar 4 2017, 03:43 PM
I believe folks with enough fabrication skills have used the stock wheel hub after removing the wheel by grinding out the rivets and then tapping holes for the Momo wheel. Quite involved but you may have few options.
This is what I have started doing on my current 914 and did on my previous one as well.
My first 914 I cut the steering wheel center hub and attached the MOMO wheel directly to this. The downfall to this is that you don't have a nice transition from the turn signal switches to the MOMO steering wheel. there is a black plastic ring behind the steering wheel that fills in the "void" and makes a nice transition here.
On my current 914 I am trying to keep the "stock" look and have begun designing the below adapter. The 6 holes match up with the MOMO steering wheel and run the entire length of the adapter. The plan is to tap the holes so the MOMO steering wheel attaches and then you can bolt the adapter to the 914 steering wheel center section. A little modification needs to be done to the center section to complete the design so the horn button can be used, but all in due time. The horn button will be a press fit as it seems MOMO designed it this way to begin with.
(IMG:http://www.914world.com/bbs2/uploads_offsite/imgur.com-9067-1488663807.1.jpg)
cal914   Fitting Momo steering wheel   Mar 3 2017, 02:52 PM
GeorgeRud   I believe the hub may have been discontinued so yo...   Mar 3 2017, 03:01 PM
stevend914   Im looking to fit a Momo steering to my 1971 914 ...   Mar 3 2017, 04:36 PM
brubou   Im looking to fit a Momo steering to my 1971 914 ...   Mar 3 2017, 06:09 PM
Rleog   The Momo adapter for 70-early 71 914s is no longer...   Mar 3 2017, 06:37 PM
ndfrigi   When I still have the 71 1.7 megasquirt, i planned...   Mar 3 2017, 07:16 PM
Blue6   Agree with Noel, the momo part number you need is ...   Mar 3 2017, 07:35 PM
porschetub   Yes exactly,found 2 early ones on ebay,late are 80...   Mar 3 2017, 08:53 PM
plays with cars   Bummer, thought that I had one for you. But I che...   Mar 3 2017, 09:01 PM
7TPorsh   I had the same problem finding one. Finally found ...   Mar 3 2017, 09:22 PM
turnaround89   This is what I have started doing on my current ...   Mar 4 2017, 03:43 PM
Tjmrfe   Im looking to fit a Momo steering to my 1971 914 ...   Mar 4 2017, 04:01 PM
Tjmrfe   Im looking to fit a Momo steering to my 1971 914...   Mar 4 2017, 04:05 PM
GregAmy   Has anyone tried installing a later upper column t...   Mar 4 2017, 04:23 PM
BeatNavy   Has anyone tried installing a later upper column ...   Mar 4 2017, 05:57 PM
GregAmy   Yes and no: http://www.914world.com/bbs2/index.p...   Mar 5 2017, 07:26 PM
BuddyV   What is the Momo hub model # for later cars... .sa...   Mar 6 2017, 09:11 PM
GregAmy   What is the Momo hub model # for later cars... .s...   Mar 6 2017, 09:45 PM
JoeD   What is the Momo hub model # for later cars... .s...   Mar 7 2017, 09:37 AM
sithot   I'm on my second 8002 and it's not going o...   Nov 1 2021, 02:59 PM
vin man   For my 1971 914-4, I ordered one of these from Cla...   Mar 7 2017, 09:10 AM
GreatPumpkin   So I’ve been looking for answers on this for som...   Nov 2 2022, 03:47 PM
sithot   At the end of the day, all three will fit just ...   Nov 2 2022, 07:54 PM
Varooom   Here is my newly added Momo 370mm. Size is factory...   Nov 2 2022, 04:35 PM
GreatPumpkin   Here is my newly added Momo 370mm. Size is factor...   Nov 2 2022, 04:46 PM
Varooom   Here is my newly added Momo 370mm. Size is facto...   Nov 3 2022, 11:02 AM
Cairo94507   Very nicely done- that looks great. :beer2:   Nov 2 2022, 05:05 PM
r_towle   Can’t recall, but I made a ring that bolted on t...   Nov 2 2022, 06:04 PM
dr914@autoatlanta.com   Jeff at Classico steering wheels sells an adaptor ...   Nov 3 2022, 02:46 PM
Retroracer   Im looking to fit a Momo steering to my 1971 914 ...   Nov 3 2022, 04:30 PM
sithot   Apparently the Solid Hub 8002 is all there is for ...   Nov 9 2022, 06:53 AM
scott_in_nh   About 10 years ago my son bought and installed a P...   Jan 27 2023, 09:26 AM
GregAmy   That may be a JDM Momo steering wheel, some Japane...   Jan 27 2023, 09:43 AM
scott_in_nh   That may be a JDM Momo steering wheel, some Japan...   Jan 27 2023, 10:03 AM
gokart73   That’s a Niki Lauda Momo from the late ‘70’s...   Jan 27 2023, 03:08 PM
scott_in_nh   That’s a Niki Lauda Momo from the late ‘70’...   Jan 27 2023, 03:47 PM
Freezin 914   That’s a Niki Lauda Momo from the late ‘70â€...   Jan 27 2023, 08:57 PM
scott_in_nh   I did install the longer of the two 8002's wit...   Jan 27 2023, 04:23 PM
SKL1   Glad I got the MOMO Jackie Stewart wheel and adapt...   Jan 27 2023, 10:23 PM
CCE   Got my momo from Amazon, with a Porsche hub, did n...   Jan 28 2023, 02:55 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:47 AM
