| michaelmoo |
Oct 26 2004, 04:53 AM
Member ![]() ![]() Group: Members Posts: 312 Joined: 21-May 04 From: Kennesaw, GA Member No.: 2,092 |
I need help with something that is simple that I forgot to write down when working on my car. (My fault….).
I need info on the wiring that goes from the wiring harness/coil/dizzy (that has the Pertornx). I have four wire coming out of the wiring harness by the dizzy (red,green,and two blacks). The red and green go to the oil press sending unit, so that leaves two blacks. Out of the dizzy is a red and black wire. I believe the red wire goes to the + side of the coil and the black (dizzy) to the – side of the coil. Were to the two from the wiring harness go? |
| Joe Ricard |
Oct 26 2004, 05:51 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Seems you are missing one. Black purple 14 gauge is for the 12 to the coil (positive) the smaller wire 16 ga. from the harness is black it is for the tach. Since these cars are old you may just want to put a meter on the wires to verify your predecessor ain't trying to screw you. Yes the green and red is from the oil pressure idiot light. Seems your Petronics will be wired right (as per your installation instructions.
michaelmoo wiring help (shouldn't be hard) Oct 26 2004, 04:53 AM
michaelmoo Thanks.
ok so know it should look like this. but w... Oct 26 2004, 07:23 AM
michaelmoo bump Oct 26 2004, 09:35 AM
michaelmoo hello.....:alfred: Oct 26 2004, 11:07 AM
Demick The tach wire goes to the - terminal on the coil.
... Oct 26 2004, 11:15 AM
Demick Oil pressure sender shouldn't have 2 wires goi... Oct 26 2004, 11:24 AM
bondo Perhaps the extra wires are for the trigger points... Oct 26 2004, 11:28 AM
Demick I'm pretty sure trigger points wires are all w... Oct 26 2004, 11:35 AM
michaelmoo I have carbs, oil press gauge, and (do not kill me... Oct 26 2004, 11:38 AM
Joe Ricard By the looks of the drawing the car should run. P... Oct 26 2004, 12:03 PM
michaelmoo Thanks!! :trophy: Oct 26 2004, 12:27 PM
SLITS The other wire should/could be for the thermotime ... Oct 26 2004, 01:13 PM
Doug Leggins I have a 72 with carbs and a pertronix. I also hav... Oct 26 2004, 08:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th July 2026 - 09:52 PM |
