> Lift options? Brands, recomendations experiences, looking for informed opinions
Calwaterbear
post Mar 22 2017, 12:46 PM
Guys,
I'm getting ready to pull the trigger on a 2 post lift. while the 914 is light, I alsoi have to hoist up a LandRover Defender 110 as well, weighing in at 6500 - 7000 lbs.
I'm thinking a 9000 lbs rated lift will be fine.
But there are several different brands now available - with a WIDE range in prices.
so the cheap ones include
Launch (they now have a 1 piece design for towers), Autocraft, and Tuxedo. I assume all are probably Chinese - but I don't know for sure. all could be had for under 1500 - plus I will need to pour a 20X25 slab.
The Greg smith Elite seems like a good price for a unit they brag about, and have good reviews posted - but by whom?
Further up the price line - add an extra 500 - 800 bucks is the Bendpak, I think they are good quality
then some really pricey units above that.
so anyone have any idea on suitability - I'm using the lift once a month or so, i'm just a lazy hobbyist!
burton73
post Mar 22 2017, 01:15 PM
Senior member, and old dude
I have a Dannmar 4 post.
It says that the • Power Unit Made in USA
• Visible Locking system for added security
• Runways constructed of solid plate steel
• Runways coated with the best nonskid textured surface available
• Two-hose hydraulic system eliminates leaks
I have the Aluminum Approach Ramps [Add $295.00] more as the steel has been too heavy for my bad back at 54lb compared to 17lb
http://www.dannmar.com/dannmar-products/fo...t-lifts/D-7.asp
https://www.bestbuyautoequipment.com/4-post...CFc61wAodZ9cMOg
I do not remember what I paid for it as my friend bought a number and gave me a deal, my price was with delivery and set up. When I moved the guy moved it across town and set it up for $500. I have seen these sold at Costco’s as well. It is not very tall and fits 2 Porsches in a standard garage but you have to see how you get into the garage as far as the doors. Also if you have a center lift power door it may need to be changed.
I am selling my unit and that may be good for a guy in the Los Angeles area.
My buddy has used this brand for 20 years and never had a problem.
Bob B
Lifting Capacity: 7,000 lbs. / 5443 kg.
Overall Width: 105" / 2667 mm.
Outside Length: 170-1/2" / 4331 mm.
Overall Length: 203-1/2" / 5169 mm.
Height Columns: 82" / 2083 mm.
Minimum Runway Height: 4-1/2" / 114 mm.
Maximum Rise: 68" / 1791 mm.
Maximum Lifting Height: 72.5" / 1841 mm.
Width Between Columns: 92-1/2" / 2350 mm.
Runway Width: 18-1/2" / 470 mm.
Width Between Runways: 37-1/2" / 953 mm.
Runway Centerline: 52-1/4" / 1327.14 mm.
Outside Edge of Runways: 74-1/2" / 1892.3 mm.
Drive-Thru Clearance: 68" / 1727.19 mm.
Length of Runways: 160-1/2" / 4077 mm.
Locking Positions: 10
Lock Spacing: Every 4-1/2" / 114 mm.
Lifting Time: 45 Seconds
Standard Motor: 110 VAC 60Hz. 1Ph
Shipping Weight (lbs): 1550
Calwaterbear   Lift options? Brands, recomendations experiences   Mar 22 2017, 12:46 PM
burton73   I have a Dannmar 4 post. It says that the • Po...   Mar 22 2017, 01:15 PM
flyer86d   I installed a Bend Pack 10,000lb extra wide two po...   Mar 22 2017, 01:15 PM
Mark Henry   I have an AAMCO 7000lbs two post, way better than ...   Mar 22 2017, 07:15 PM
DamonsCarrera   I've always had good experience with Bendpak. ...   Mar 22 2017, 04:46 PM
TM_Corey   I've always had good experience with Bendpak....   Mar 22 2017, 06:49 PM
Jett   I've always had good experience with Bendpak...   Mar 22 2017, 08:51 PM
N_Jay   My OCD is pleased with this photo.... My OCD is ...   Mar 24 2017, 08:43 AM
jim912928   I have a Dannmar for going on 6+ years. Works per...   Mar 22 2017, 04:58 PM
somd914   I've had a Greg Smith BP8000 two post for 1.5 ...   Mar 22 2017, 06:38 PM
Cairo94507   I had a BendPak 4 post in my last house and loved ...   Mar 22 2017, 07:38 PM
strawman   I've got an Atlas 9k direct-drive (no chains) ...   Mar 22 2017, 10:26 PM
carr914   I've got a Rotary - 11 Years now, not a single...   Mar 23 2017, 04:48 AM
Perry Kiehl   Rotary. Mine is about 21 years old, no troubles   Mar 23 2017, 05:09 AM
Chris Scott   http://www.twinbusch.com/product_info.php?products...   Mar 23 2017, 08:36 AM
jsaum   What type of anchors are used to secure it to the ...   Mar 23 2017, 09:38 PM
DamonsCarrera   These ... anchor bolts   Mar 24 2017, 06:57 AM
Ferg   These ... anchor bolts Another vote for Bend P...   Mar 24 2017, 08:57 AM
rudedude   I have a rotary 7000# 2 post hoist that came out o...   Mar 24 2017, 07:55 AM
Calwaterbear   Yeah, I am familiar with the concrete issue. The...   Mar 24 2017, 09:08 AM
dcheek   I've had a Greg Smith BP8000 for over 2 years....   Mar 24 2017, 09:28 AM
r_towle   Greg smith 4 post lift, hydraulic piston failed af...   Mar 24 2017, 10:23 AM
Calwaterbear   thanks for all the input guys. I like 4 post lift...   Apr 2 2017, 09:54 AM
Mark Henry   It was 10 years old, had new cables and tubes. ...   Apr 2 2017, 11:27 AM
Calwaterbear   [quote name='Calwaterbear' post='2470981' date='A...   Apr 2 2017, 04:50 PM
- Lo-Fi Version Time is now: 20th November 2026 - 03:10 PM
