914-6 engine, newly aquired |
car guy |
Jul 25 2017, 07:15 AM
Newbie Group: Members Posts: 9 Joined: 25-July 17 From: Houston, Texas Member No.: 21,283 Region Association: None |
Hello everyone! New Member here.
I just acquired a 914 engine that was disassembled 4747. I purchased it and was told it was a 1970 2.2T motor and wanted to build it as a project back to original specs that is still my plan unless someone needs it. I would also be interested in some opinions. Since when I purchased it and it was represented as a 1970 911 2.2T motor and it is a 914-6 motor did I get the better end of the deal? which motor is more valuable? |
gms |
Jul 26 2017, 09:20 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
A 914/6 engine is not very powerful and anyone doing a conversion would probably chose sometime of a larger displacement because it cost about the same to rebuild a 3.0 L as it does to do 2.0L. I am not disparaging these engines but just trying to put a realistic value because I see people charging over $1500 for a case and as far as I am concerned that is nuts unless you own the car it belongs to. If you rebuild a 914/6 engine then you are raising the price that the owner of the car it belongs to has to pay and not knowing your abilities as an engine builder might make that a hard sell.
Eric_Shea |
Jul 26 2017, 12:58 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
A 914/6 engine is not very powerful and anyone doing a conversion would probably chose sometime of a larger displacement because it cost about the same to rebuild a 3.0 L as it does to do 2.0L. I am not disparaging these engines but just trying to put a realistic value because I see people charging over $1500 for a case and as far as I am concerned that is nuts unless you own the car it belongs to. If you rebuild a 914/6 engine then you are raising the price that the owner of the car it belongs to has to pay and not knowing your abilities as an engine builder might make that a hard sell. (IMG:style_emoticons/default/agree.gif) Those Mag case 2.0 and 2.2 motors are some of, if not the, least desirable motors to build anything off. If you can find the owner of the car it may have some value. |
Lo-Fi Version | Time is now: 31st May 2024 - 11:25 PM |
