| tazz9924 |
Jul 28 2017, 04:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 755 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
as the title states what is the best way to remove the ball joint from the control arm with out the proper tool?
| Mitox |
Jul 28 2017, 06:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 581 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States
Just buy the tool. As stated earlier they're less than $25, and it works quickly.
tazz9924 what is the best way to remove a ball joint without the tool? Jul 28 2017, 04:10 PM
fixer34
as the title states what is the best way to remov... Jul 28 2017, 04:30 PM
theer Try heating the housing (with a torch) then hold o... Jul 28 2017, 04:34 PM
Optimusglen He's wondering about the ball joint from the c... Jul 28 2017, 04:34 PM
toolguy do you mean the steering tie rod to strut? Pickle... Jul 28 2017, 05:14 PM
Mark Henry The round 4 slot nut on the bottom?
There's a... Jul 28 2017, 06:21 PM
Mark Henry I think it's this one https://www.amazon.com/P... Jul 28 2017, 06:28 PM
rgalla9146 The one that does the steering is a tie rod end.
... Jul 28 2017, 06:49 PM
mepstein Buy the proper tools. The pickle fork is cheap. Th... Jul 28 2017, 06:59 PM
porschetub Buy the tool,really not expensive,if you own a 914... Jul 28 2017, 07:08 PM
rgalla9146 OOPS, I just checked at Baum tools.
It is n... Jul 28 2017, 07:09 PM
Valy The tool won't get that crown nut out. Use a b... Jul 28 2017, 07:48 PM
The tool won't get that crown nut out. Use a ... Jul 28 2017, 08:12 PM
cary
The tool won't get that crown nut out. Use a... Jul 29 2017, 08:17 AM
914Sixer Make sure you soak the nut in PB Blaster overnight... Jul 28 2017, 08:21 PM
mepstein We use a lot of liquid heat at the shop to remove ... Jul 28 2017, 08:41 PM
tazz9924 i got in on and off real good with a pipe wrench a... Jul 29 2017, 02:01 AM
frostyf I wanted to ask for some tips or advice on this to... Sep 15 2020, 09:37 PM
VaccaRabite
I wanted to ask for some tips or advice on this t... Sep 16 2020, 06:26 AM
mepstein I disagree with Zach. I’ve removed the ballpoint... Sep 16 2020, 06:26 AM
frostyf
I disagree with Zach. I’ve removed the ballpoin... Sep 16 2020, 06:35 AM
I disagree with Zach. I’ve removed the ballpoi... Sep 16 2020, 01:27 PM
VaccaRabite Sounds like there is a much better tool now then t... Sep 16 2020, 07:30 AM
frostyf
Sounds like there is a much better tool now then ... Sep 16 2020, 10:20 AM
930cabman Just did this today, the tie rod end came off easy... Jan 30 2023, 05:27 PM
r_towle Rent the tool… Jan 30 2023, 05:40 PM
930cabman
Rent the tool…
Round nut with 4 prongs? Jan 30 2023, 05:43 PM
rhodyguy Bottom nut? Copious amounts of AeroKroil and air c... Jan 30 2023, 05:46 PM
930cabman Bottom nut came off easily with heat/pipe wrench. ... Jan 30 2023, 05:48 PM
r_towle Oh THAT nut…
What he said, every time ^^^^^^ Jan 30 2023, 08:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th November 2026 - 01:52 AM |
