| tazz9924 |
Jul 28 2017, 04:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 755 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
as the title states what is the best way to remove the ball joint from the control arm with out the proper tool?
| mepstein |
Jul 28 2017, 08:41 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,999 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
We use a lot of liquid heat at the shop to remove corroded nuts and bolts. Touch some wax to it once it's hot. Doesn't have the fumes like the solvent based penetrating oils.
tazz9924 what is the best way to remove a ball joint without the tool? Jul 28 2017, 04:10 PM
fixer34
as the title states what is the best way to remov... Jul 28 2017, 04:30 PM
theer Try heating the housing (with a torch) then hold o... Jul 28 2017, 04:34 PM
Optimusglen He's wondering about the ball joint from the c... Jul 28 2017, 04:34 PM
toolguy do you mean the steering tie rod to strut? Pickle... Jul 28 2017, 05:14 PM
Mark Henry The round 4 slot nut on the bottom?
There's a... Jul 28 2017, 06:21 PM
Mark Henry I think it's this one https://www.amazon.com/P... Jul 28 2017, 06:28 PM
rgalla9146 The one that does the steering is a tie rod end.
... Jul 28 2017, 06:49 PM
mepstein Buy the proper tools. The pickle fork is cheap. Th... Jul 28 2017, 06:59 PM
Mitox Just buy the tool. As stated earlier they're ... Jul 28 2017, 06:59 PM
porschetub Buy the tool,really not expensive,if you own a 914... Jul 28 2017, 07:08 PM
rgalla9146 OOPS, I just checked at Baum tools.
It is n... Jul 28 2017, 07:09 PM
Valy The tool won't get that crown nut out. Use a b... Jul 28 2017, 07:48 PM
The tool won't get that crown nut out. Use a ... Jul 28 2017, 08:12 PM
cary
The tool won't get that crown nut out. Use a... Jul 29 2017, 08:17 AM
914Sixer Make sure you soak the nut in PB Blaster overnight... Jul 28 2017, 08:21 PM
tazz9924 i got in on and off real good with a pipe wrench a... Jul 29 2017, 02:01 AM
frostyf I wanted to ask for some tips or advice on this to... Sep 15 2020, 09:37 PM
VaccaRabite
I wanted to ask for some tips or advice on this t... Sep 16 2020, 06:26 AM
mepstein I disagree with Zach. I’ve removed the ballpoint... Sep 16 2020, 06:26 AM
frostyf
I disagree with Zach. I’ve removed the ballpoin... Sep 16 2020, 06:35 AM
I disagree with Zach. I’ve removed the ballpoi... Sep 16 2020, 01:27 PM
VaccaRabite Sounds like there is a much better tool now then t... Sep 16 2020, 07:30 AM
frostyf
Sounds like there is a much better tool now then ... Sep 16 2020, 10:20 AM
930cabman Just did this today, the tie rod end came off easy... Jan 30 2023, 05:27 PM
r_towle Rent the tool… Jan 30 2023, 05:40 PM
930cabman
Rent the tool…
Round nut with 4 prongs? Jan 30 2023, 05:43 PM
rhodyguy Bottom nut? Copious amounts of AeroKroil and air c... Jan 30 2023, 05:46 PM
930cabman Bottom nut came off easily with heat/pipe wrench. ... Jan 30 2023, 05:48 PM
r_towle Oh THAT nut…
What he said, every time ^^^^^^ Jan 30 2023, 08:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th November 2026 - 01:52 AM |
