Replacement Relay Socket Panel, Updated: Version 3 - Solid State Relays and Fuse Panel Replacement |
Evan0 |
Apr 30 2017, 10:12 AM
Newbie Group: Members Posts: 44 Joined: 13-February 17 From: Southern California Member No.: 20,837 Region Association: Southern California |
Update 3 Post
I've been rewiring my car for the last few weeks and part of that was replacing the factory fuse panel with one that uses modern fuse from JWest Engineering. I was unhappy with the existing relay sockets that I found. As a result of that, I designed and printed a monolithic fuse socket for all the relays, buzzer, and flasher unit. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20837-1493568735.1.jpg) After mounting it to the fuse panel. The buzzer is a Hella H35394001. The horn, blower, and fog relays are Hella 933332051. The flasher unit is a Hella 009492101. The head light relay is a modern reproduction of the VW one. Still waiting on the flasher unit to ship. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20837-1493568735.2.jpg) I'll be posting the STL files, Bill of Materials, and instructions after I've worked out a few kinks. I would love any feedback or suggestions on improvements. |
McMark |
Aug 15 2017, 01:44 PM
Thought of something...
While I love the wire color printed on the board, I thought some of the wire colors changed on different years. It may be better to simply label each connection with the original relay pin number (30, 85, 86, 87, 87a). If I were troubleshooting a car with that board installed and I wouldn't want to have to pull out and analyze the wiring diagram to translate wire colors to pin number and function. On the fuse board, it would be prudent to add either a couple extra constant power connections and a couple switched power connections, OR add a couple extra fuses for add-ons. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:18 PM |
