| 914 RZ-1 |
Aug 20 2017, 02:27 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I've just noticed the hoses from the charcoal canister to the engine have been cut (down in the front fender well). Is it necessary to replace these or can I get rid of the canister and hoses? Do I just plug the connections in the fan shroud and air intake if I do get rid of it?
| GeorgeRud |
Aug 21 2017, 09:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
No benefit to removing them so why not minimize the gas smell? With all the modern fuel injected cars, folks have forgotten what carbs used to smell like. Modern ethanol laced fuels also contribute more smell due to their higher vapor pressure and lower boiling points.
| SirAndy |
Aug 21 2017, 10:56 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,453 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
With all the modern fuel injected cars, folks have forgotten what carbs used to smell like. I have modern fuel injection and i get *lots* of gasoline smell without the charcoal canister system. The smell comes from the tank overflow since that is where i routed the evap hose into when i removed the canister. Anything over 1/2 tank of gas and you feel like you're sniffing gas straight out of the nozzle. (IMG:style_emoticons/default/icon8.gif) |
914 RZ-1 Charcoal system Aug 20 2017, 02:27 PM
Mike D. Probably why you smell gasoline all the time :D Aug 20 2017, 02:46 PM
914 RZ-1 After doing a bit of research it seems the caniste... Aug 20 2017, 05:24 PM
mgp4591
After doing a bit of research it seems the canist... Aug 20 2017, 05:49 PM
Tjmrfe
After doing a bit of research it seems the canist... Aug 20 2017, 06:02 PM
Vacca Rabite Do you need it? No. Do you want it? Yes.
Zach Aug 20 2017, 05:44 PM
Jeff Bowlsby Try McMaster Carr Aug 20 2017, 06:46 PM
914 RZ-1
Try McMaster Carr
Like this:
https://www.mcmast... Aug 20 2017, 09:12 PM
mepstein Vacuum lines Aug 20 2017, 07:17 PM
Optimusglen More necessary with a fuel system that has a feed ... Aug 20 2017, 07:53 PM
SirAndy can I get rid of the canister and hoses?
Do you l... Aug 20 2017, 09:26 PM
pete000 I think the Euro spec cars didnt run them?
My wif... Aug 20 2017, 10:38 PM
With all the modern fuel injected cars, folks ha... Aug 21 2017, 11:07 AM
Mark Henry How would you run it to a rain hat weber /6, ... Aug 21 2017, 11:24 AM
How would you run it to a rain hat weber /6, ... Aug 21 2017, 11:40 AM
Mark Henry
How would you run it to a rain hat weber /6, ... Aug 21 2017, 12:56 PM
Philip W. I have not had fumes ever since making sure the ve... Aug 21 2017, 11:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 03:19 AM |
