| 914 RZ-1 |
Aug 20 2017, 02:27 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I've just noticed the hoses from the charcoal canister to the engine have been cut (down in the front fender well). Is it necessary to replace these or can I get rid of the canister and hoses? Do I just plug the connections in the fan shroud and air intake if I do get rid of it?
| Mark Henry |
Aug 21 2017, 11:24 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
How would you run it to a rain hat weber /6, '74 conversion?
I have it plugged right now and this has got me thinking, but I'd have to relocate the canister. |
| SirAndy |
Aug 21 2017, 11:40 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,453 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
How would you run it to a rain hat weber /6, '74 conversion? I have it plugged right now and this has got me thinking, but I'd have to relocate the canister. All you need is pressure which you should be able to get from the fan shroud on a /6 and then route the return to one of your rain hats. There should be enough suction (even at idle) to suck in the fumes and burn them without generating more fuel smell in the engine compartment. I've been thinking about doing exactly that and routing the return into the K&N air filter on my FI intake. (IMG:style_emoticons/default/smile.gif) |
| Mark Henry |
Aug 21 2017, 12:56 PM
How would you run it to a rain hat weber /6, '74 conversion? I have it plugged right now and this has got me thinking, but I'd have to relocate the canister. All you need is pressure which you should be able to get from the fan shroud on a /6 and then route the return to one of your rain hats. There should be enough suction (even at idle) to suck in the fumes and burn them without generating more fuel smell in the engine compartment. I've been thinking about doing exactly that and routing the return into the K&N air filter on my FI intake. (IMG:style_emoticons/default/smile.gif) Sounds easy enough, To do list...it's always one line scratched off, two more lines added... (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/rolleyes.gif) |
914 RZ-1 Charcoal system Aug 20 2017, 02:27 PM
Mike D. Probably why you smell gasoline all the time :D Aug 20 2017, 02:46 PM
914 RZ-1 After doing a bit of research it seems the caniste... Aug 20 2017, 05:24 PM
mgp4591
After doing a bit of research it seems the canist... Aug 20 2017, 05:49 PM
Tjmrfe
After doing a bit of research it seems the canist... Aug 20 2017, 06:02 PM
Vacca Rabite Do you need it? No. Do you want it? Yes.
Zach Aug 20 2017, 05:44 PM
Jeff Bowlsby Try McMaster Carr Aug 20 2017, 06:46 PM
914 RZ-1
Try McMaster Carr
Like this:
https://www.mcmast... Aug 20 2017, 09:12 PM
mepstein Vacuum lines Aug 20 2017, 07:17 PM
Optimusglen More necessary with a fuel system that has a feed ... Aug 20 2017, 07:53 PM
SirAndy can I get rid of the canister and hoses?
Do you l... Aug 20 2017, 09:26 PM
pete000 I think the Euro spec cars didnt run them?
My wif... Aug 20 2017, 10:38 PM
GeorgeRud No benefit to removing them so why not minimize th... Aug 21 2017, 09:41 AM
SirAndy With all the modern fuel injected cars, folks hav... Aug 21 2017, 10:56 AM
With all the modern fuel injected cars, folks ha... Aug 21 2017, 11:07 AM
Philip W. I have not had fumes ever since making sure the ve... Aug 21 2017, 11:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 03:19 AM |
