> What are higher powered 914s like?, I've never had the chance to drive one.
anthony
post May 15 2003, 02:46 PM
2270 club
Like every 914 owner I've been thinking I want more power. You know, I'd like to at least be able to smoke a Mini Cooper S or a Honda Civic Si without breaking a sweat.
I've been collecting parts to build a 2056 2L engine. I keep wondering if it's worth it.
Or, will I still want more hp in the end?
What kind of horsepower does it take to make a 914 into a 0-60 8 second car (Civic Si), a 7 second car (Mini S), or a 6 second car (S2000)???
TIA
Mueller
post May 16 2003, 11:57 AM
914 Freak!
No factory cars (these days) are designed for drag racing that I know of....sure the Mustangs and Cameros are good at it, but they also handle "okay"
If anything, the 914 should be better suited for this type of racing than a front engined car (Top Fuel cars are sorta Mid-engined)
The key thing Anthony is balance and putting together a well rounded package that is not overkill in any one area (suspension too stiff or a motor that must reach 5k before the power comes on (S2000) )
A high horsepower 914 does not have to be a chore to drive on the street...most people just start thumbing thur the catalogs and ordering the biggest baddest stiffest suspension parts they can find since they think they will need it due to the bigger more powerful engine.
What you need to do is research the cars that you are interested in being able to "compete" with....study thier HP and weight and gearing, what you want to do is come close or better in some areas to meet or exceed thier numbers.
I'd also recommend taking these cars out for a test drive..sure the numbers might look good on paper, but are they practicle???
Also, don't just focus on the "numbers"....see what size tires they run and find out the spring rates if possible. The Honda S2000 is putting 240 hp down on the road with 205 tires....so what's the problem? Yea, it's more modern car, but thier is nothing wrong at all with the design of the 914 to be able to achieve the same results.
S2000 specs
Civic Si specs
Cooper S specs
For those that are "complaining" that they can too easily spin the the tires in first or second, look at the gearing, the tires and the alignment (this will also be a comprimise...an alignment that will be great on a big track, might not be the best for optimal traction or braking in straight lines)
For my 914, I am doing what I am preaching here.....balance and nothing overkill in any department...I'm running bigger swaybars, but softer springs...etc...etc...
anthony   What are higher powered 914s like?   May 15 2003, 02:46 PM
J P Stein   Wanna "do" an S2000? Forget about a 4 pooper. You...   May 15 2003, 02:56 PM
Jeff Krieger   Couldn't you just cheat and install nitrous? B...   May 15 2003, 03:30 PM
cha914   I have a 2056 w/130hp to the flywheel...I think it...   May 15 2003, 03:31 PM
Ferg   Having just moved from a 2.0 four to a 2.7 six I c...   May 15 2003, 03:32 PM
campbellcj   I recently got a ride in an ~1800lb open cockpit 9...   May 15 2003, 03:52 PM
Don Wohlfarth   Anthony, it may be cheaper to buy a S2000 instead ...   May 15 2003, 04:27 PM
anthony   I hear ya Don. A low mileage 180hp 911 SC for arou...   May 15 2003, 04:36 PM
Aaron Cox   v-8 sleeper? :D ive seen a rotary powered teene...   May 15 2003, 04:42 PM
Blynes   I don't know how much power my car has exactly...   May 15 2003, 04:55 PM
Aaron Cox   whadda bout a turbo? didnt someone on this list ha...   May 15 2003, 04:57 PM
Aaron Cox   was it turboshyu?   May 15 2003, 04:58 PM
krk
  May 15 2003, 07:21 PM
mskala   You shouldn't be using 0-60 numbers to compare...   May 15 2003, 07:50 PM
TimT   My 911 is 200 hp on a good day, it weighs about #...   May 15 2003, 07:58 PM
krk   <...   May 15 2003, 09:47 PM
campbellcj     May 15 2003, 10:01 PM
tesserra   I had a '76 2.0, bone stock. The slowest 914. ...   May 15 2003, 10:51 PM
Don Wohlfarth   Kim, when I said mistakenly that refers to "been t...   May 16 2003, 09:40 AM
need4speed   Well, the other thing is - the 914 isn't reall...   May 16 2003, 11:04 AM
airkewl   I have two original 914-6s. One is bone stock, ot...   May 16 2003, 11:16 AM
Mueller   No factory cars (these days) are designed for drag...   May 16 2003, 11:57 AM
72Signal914   I don't about you all but I am perfectly happy...   May 16 2003, 12:19 PM
J P Stein   Heh,heh, I love this shit. Some background I star...   May 16 2003, 01:32 PM
Brad Roberts   Anthony, Stop by the shop (SSI)..You'll never...   May 16 2003, 02:16 PM
J P Stein   I watched while Brad reached thru the drivers wind...   May 16 2003, 02:30 PM
Brad Roberts   I want driveability for a street car... The carbed...   May 16 2003, 02:35 PM
jfort   great discussion, you guys. thanks! I hope J...   May 16 2003, 02:46 PM
joea9146     May 16 2003, 02:56 PM
Brad Roberts   Ha ha yes it is... but the 3.2 fan is louder.. and...   May 16 2003, 02:56 PM
seanery   I just went for a ride in a stock 3.2 powered car....   May 17 2003, 11:46 PM
anthony   This turned out to be a great thread. Brad I'm...   May 18 2003, 01:16 PM
Bleyseng   What do decent 3.2 engines go for in Calif? Up her...   May 18 2003, 04:05 PM
si2t3m   Yeah, the webered 3.0L in my 914 drinks gas like...   May 18 2003, 07:32 PM
Brad Roberts   They go for 5500$ down here Geoff. You can ge...   May 19 2003, 07:37 AM
- Lo-Fi Version Time is now: 11th August 2025 - 06:48 AM
