GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
Mikey914 |
Feb 27 2018, 10:47 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are looking at making an improved version of the throttle cable utilizing a thicker cable. We will be using the architectural cable we use in other applications. There has been some issue with fatigue on some of the cables currently on the market.
If there's enough interest we can easily make these with this more rugged cable. Who's in? |
Luke M |
Mar 1 2018, 01:09 PM
Senior Member Group: Members Posts: 1,377 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Hi Mark,
Here's the 914-6 cable pics and info we pm'd about. over all length is : 99 1/4'' from end to end the sheathing is : 41 3/4'' from end to end the metal threaded part that mounts on the trans bracket is : 55 mm from end to end the pedal and trans threaded ends for the cup/ball socket is : 38 mm from end to end cable thickness is 2 mm and has a plastic coating on the cable itself. The pics of the 6 trans and carb manifolds are so you get an idea on how the cable mounts/runs. Let me know if you need more info. Luke Attached image(s) |
porschetub |
Apr 9 2018, 11:54 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi Mark, Here's the 914-6 cable pics and info we pm'd about. over all length is : 99 1/4'' from end to end the sheathing is : 41 3/4'' from end to end the metal threaded part that mounts on the trans bracket is : 55 mm from end to end the pedal and trans threaded ends for the cup/ball socket is : 38 mm from end to end cable thickness is 2 mm and has a plastic coating on the cable itself. The pics of the 6 trans and carb manifolds are so you get an idea on how the cable mounts/runs. Let me know if you need more info. Luke But isn't that an extended pivot rod off the RH side inlet manifold,is that stock or part off the RJ conversion parts,intersested to know, (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 12:04 PM |
