considering replacing the backpad with carpet?Update Completed wanted to share pics, backpad replace |
jrblackbox |
Feb 13 2018, 01:08 PM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
Updated -I am thinking of removing the standard backpad. Anyway, I have a couple of questions. What should I cover the firewall with, perlon or carpet? Pros and cons of either? I would imagine that the sound insulator would need to come out and then glue the perlon/carpet to the bare metal? Is there anything I can do to reduce the additional noise? where can I relocate the backpad light? Any help and or suggestions appreciated, got any pics of yours post them please! TIA
Completed changing the backpad to perlon, wanted to share a couple pics. |
mb911 |
May 22 2018, 01:18 PM
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I really like it.. Now I need to source the kit or material.
mepstein |
May 22 2018, 01:47 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I really like it.. Now I need to source the kit or material. The kits are pieced together but only seem to come in grey. I want black. 914rubber has perlon for a good price and your choice of backed or not. I believe you want to buy the non backed perlon because it will stretch and mold around the firewall. I’m using some self adhesive rubber soundproofing that I bought on amazon. It’s pretty thick so I will spray adhesive and lay the perlon directly on the rubber. I also have to grind off the clips that hold up the backpad and maybe fill the screw holes. |
mb911 |
May 22 2018, 02:01 PM
I really like it.. Now I need to source the kit or material. The kits are pieced together but only seem to come in grey. I want black. 914rubber has perlon for a good price and your choice of backed or not. I believe you want to buy the non backed perlon because it will stretch and mold around the firewall. I’m using some self adhesive rubber soundproofing that I bought on amazon. It’s pretty thick so I will spray adhesive and lay the perlon directly on the rubber. I also have to grind off the clips that hold up the backpad and maybe fill the screw holes. I went with a charcoal carpet so grey will work perfect for me.. Good to know.. |
Lo-Fi Version | Time is now: 10th June 2024 - 10:00 AM |
