> Southern California '75 914 repaint and refresh, Finally started after 33 years of ownership.
drem914
post Jul 4 2018, 10:59 AM
Well its been over 33 years that I have owner this car as the 3rd owner.
I have finally broken down and am getting the surface rust repaired and having the car fully resprayed. I am told it should be ready by Mid August. The car was torn down this week and the good news is that after 33 years of mud and dirt in the rockers that there is no rust. (IMG:style_emoticons/default/piratenanner.gif) Surprising, as the car first came in to the country in Chicago and wound up spending time in San Francisco before I got it.
The rest of the car had a few rust bubbles at the base of the windshield and on the passenger door along with the usual dents and dings that come with keeping a car in a garage with little kids opening the car door next to it or traveling the So Cal freeways and picking up misc. road debris impacts.
The car is going to stay its' original color "Ancona Blue" along with all of the appearance group finishes.
As progress continues I'll continue to update.Thanks for looking.
Tom_T
post Jul 4 2018, 11:26 AM
TMI....
QUOTE(drem914 @ Jul 4 2018, 09:59 AM) *
Make sure that your body shop looks into the area behind the doors below the sails and on the fender sides around the taillights for rusting from the factory foam in those spots holding moisture & rusting from the inside out. If they find any, then have them cut out the rusted sheet metal & the foam there so it won't reoccur, & then patch in 19 GA sheet metal to match the original body panels (or get the RD patch panels.
Same thing around the windshield, cowl-to-fender seams with the rubber gasket on top, bottoms of the doors under the outer door seals, up under the steering rack L & R where the MC &/or windshield washer bottle/hoses can leak down & rust trough the bottom floor of that well - which is where your steering rack attaches to the unibody, & in the hell hole & lower lip/shelf in the engine bay - especially behind the sound/heat pad.
I could go on & on, but you can use Jeff Bowlsby's checklist too - as if you're buying it all over again & doing a deep PPIn...
http://bowlsby.net/914/Classic/zTN_Gen_914CAF.pdf
You &/or they should do a thorough look through & check out all of the nooks & crannies for any rust evidence, as you did behind the rocker covers.
I (IMG:style_emoticons/default/wub.gif) Ancona Blue! (IMG:style_emoticons/default/drooley.gif)
Happy 4th! (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/beerchug.gif)
Tom
drem914
post Jul 4 2018, 12:00 PM
QUOTE(Tom_T @ Jul 4 2018, 10:26 AM) *
Tom
Thanks Tom. we are doing that now, but by all acoounts I have some minor surface rust in the trunk back by the lights, under the spare tire and at fender-to-cowl seam on the passenger side and that is it. The car has been garaged since I have owned it and i think that has helped alot. Everything else is good. The painter just finshed up another 914 (his own) a few months ago and is well aware of the other spots that can be problem areas. Even the hell hole is good. Dirty, but good.
Tom_T
post Jul 4 2018, 12:18 PM
TMI....
QUOTE(drem914 @ Jul 4 2018, 11:00 AM) *
Assuming it turns out as well as you expect, then you might want to share the shop recco with others in OC/SoCal who may be looking.
As for me, I'm spending the day deconstructing the irreplaceable & unmatchable 1921 ceramic tile around our kitchen sink, so that I can carefully remove it & install the new repro one, then reuse the tile surround to finish in the sink & still match the counter's tile.
Very slow going! (IMG:style_emoticons/default/blink.gif)
PS - With the darker colors, the OE big bumpers tend to look pretty good, as well as adding some protection from low speed bumps, so you're smart to leave them.
FYI - the reason you don't have the "mini-tits" (bumper warts) on there is because it was originally sold in a state other than CA & MD - which were the only 2 states requiring them in 75-76 MYs.
That also means it legally doesn't have the power robbing CA required emissions eqpt. & crapalytic converter (as well as being smog test exempt) - so it has a tad more HP than the CA GC 2.0s.
Enjoy your 4th! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/jsharp.gif)
Tom
drem914   Southern California '75 914 repaint and refresh   Jul 4 2018, 10:59 AM
Montreal914   Good luck with the project. I hope the shop keeps ...   Jul 4 2018, 11:13 AM
drem914   Good luck with the project. I hope the shop keeps...   Jul 4 2018, 11:25 AM
Tom_T   Well its been over 33 years that I have owner thi...   Jul 4 2018, 11:26 AM
drem914   Make sure that your body shop looks into the area ...   Jul 4 2018, 12:00 PM
Tom_T   Thanks Tom. we are doing that now, but by all ac...   Jul 4 2018, 12:18 PM
Coondog   Great time to back date those bumpers and lose the...   Jul 4 2018, 11:33 AM
drem914   Great time to back date those bumpers and lose th...   Jul 4 2018, 11:44 AM
Ed_Turbo   [quote name='Coondog' post='2626063' date='Jul 4 ...   Jul 25 2018, 12:59 PM
Mueller   I love that blue!   Jul 4 2018, 12:16 PM
drem914   I love that blue! The mock up looks good. W...   Jul 4 2018, 12:30 PM
Mueller   I love that blue! The mock up looks good. ...   Jul 4 2018, 12:34 PM
Tom_T   PSS - So once you have her all gussied up, I expec...   Jul 4 2018, 12:30 PM
drem914   PSS - So once you have her all gussied up, I expe...   Jul 4 2018, 01:15 PM
Tom_T   Will do. I'm not going for concourse original...   Jul 4 2018, 11:31 PM
drem914   Will do. I'm not going for concourse origina...   Jul 5 2018, 02:57 PM
Porschef   Tom, use a Fein tool with a carbide blade. Don...   Jul 4 2018, 12:45 PM
Tom_T   Tom, use a Fein tool with a carbide blade. Don...   Jul 4 2018, 11:25 PM
Coondog   Your half way there on the side marker removal if ...   Jul 4 2018, 04:45 PM
marksteinhilber   I spy an old beetle! It looks strikingly simi...   Jul 5 2018, 03:02 PM
drem914   Well the car is not blue anymore and the rust is g...   Jul 14 2018, 03:39 PM
drem914   While that is going on, I now need to get the seat...   Jul 14 2018, 03:52 PM
drem914   Stopped by Ron's today to see how he is doing ...   Jul 24 2018, 04:34 PM
drem914   Well it has been a while since I had an update on ...   Aug 25 2018, 03:14 PM
drem914   It is finally getting closer. A couple weeks from ...   Aug 25 2018, 03:20 PM
drem914   Got a nice message this afternoon from the painter...   Sep 16 2018, 05:54 PM
porschetub   Wow nice colour :wub: .   Sep 16 2018, 06:30 PM
drem914   Wow nice colour :wub: . Thanks. It's an or...   Sep 16 2018, 10:28 PM
Cairo94507   Great looking color. Congratulations on a nice job...   Sep 17 2018, 06:29 AM
effutuo101   Very nice work!   Sep 17 2018, 01:39 PM
JawjaPorsche   Looking Good! :beer2:   Sep 17 2018, 02:27 PM
drem914   Latest update on progress. Getting closer to re-as...   Sep 22 2018, 11:56 PM
drem914   Reassembly has started. :beer2:   Sep 24 2018, 03:39 PM
DRPHIL914   looks great!! beautiful color. Just went t...   Sep 25 2018, 10:25 AM
drem914   Some update photos as the re-assembly has begun. F...   Oct 11 2018, 10:39 PM
drem914   More photos from the reassembly Even have my new ...   Oct 11 2018, 10:46 PM
Tdskip   She looks great, thanks for the update.   Oct 12 2018, 06:39 AM
drem914   Today was the day to get it from the painter and t...   Oct 24 2018, 06:55 PM
drem914   Some more shots of the progress. Once again, thank...   Oct 24 2018, 06:59 PM
drem914   Next step is to straighten out some electrica...   Oct 24 2018, 07:04 PM
bbrock   That car is gorgeous! :drooley: I've sai...   Oct 24 2018, 07:25 PM
drem914   That car is gorgeous! :drooley: I've sa...   Oct 24 2018, 08:45 PM
sb914   "Big ugly bumpers"   Oct 24 2018, 08:48 PM
drem914   "Big ugly bumpers" Thanks, that is wha...   Oct 24 2018, 08:53 PM
drem914   Had not posted anything here in a bit. Currently r...   Nov 3 2018, 04:21 PM
drem914   Been awhile since I updated on what was happening....   Dec 27 2018, 06:39 PM
Cairo94507   I love your seats. :beer2:   Dec 28 2018, 07:30 AM
Montreal914   Beautiful work and progress :trophy: What is yo...   Dec 28 2018, 09:31 AM
drem914   Beautiful work and progress :trophy: What is y...   Dec 28 2018, 12:13 PM
Larmo63   Wow, everything looks great Franz!!!...   Dec 28 2018, 01:37 PM
drem914   Wow, everything looks great Franz!!!...   Dec 28 2018, 02:21 PM
drem914   Wow, everything looks great Franz!!!...   Dec 28 2018, 02:22 PM
drem914   latest update now that I have te car back home. so...   Feb 23 2019, 10:53 PM
drem914   Some more photos   Feb 23 2019, 10:59 PM
drem914   Removed the rest of the interior pieces, handbrake...   Mar 3 2019, 01:09 PM
Coondog   Car looks great. Congrats   Mar 3 2019, 01:23 PM
preach   Fantastic.   Mar 3 2019, 05:06 PM
Tom_T   Okay, it looks like you'll be ready to enter i...   Mar 3 2019, 10:32 PM
stevend914   My first 914 was a brand new 1975 Ancona Blue 1.8 ...   Mar 4 2019, 07:07 AM
Mayne   Absolutely beautiful car! Can't wait to se...   Mar 4 2019, 11:15 AM
drem914   Absolutely beautiful car! Can't wait to s...   Mar 4 2019, 11:54 AM
drem914   One step closer. :Qarl: One of the two recovere...   Mar 6 2019, 06:43 PM
drem914   one more and I was able to clear out the garage f...   Mar 6 2019, 07:14 PM
sb914   Congrats.... :wub: looking beautiful! Better...   Mar 6 2019, 09:51 PM
drem914   Congrats.... :wub: looking beautiful! Bette...   Mar 7 2019, 09:52 AM
Tdskip   Thanks for the updates, she looks great!   Mar 7 2019, 12:20 PM
914-300Hemi   Looks great. Can’t wait to see it in person.   Mar 8 2019, 09:06 AM
bbrock   Congrats! That has to feel really good - I can...   Mar 8 2019, 09:30 AM
Ed_Turbo   Just read your topic while doing some research. Ho...   Jun 27 2019, 07:10 PM
drem914   Just read your topic while doing some research. H...   Jul 1 2019, 06:17 PM
narino   Car looks great. How do you like your body man and...   Jul 1 2019, 07:10 PM
drem914   I thought I would post a couple more recent photos...   Sep 2 2019, 09:30 PM
drem914   A couple more shots   Sep 2 2019, 09:33 PM
abes914   Wow! Beautiful! :beer2:   Sep 2 2019, 09:39 PM
ndfrigi   yes it is beautiful! I missed my former 75 aga...   Sep 3 2019, 01:51 AM
Coondog   Great looking car.... :)   Sep 3 2019, 04:59 AM
- Lo-Fi Version Time is now: 1st August 2025 - 12:02 PM
