EJ20 Build Cost? |
EJ20 Build Cost? |
LanceW3544 |
Aug 5 2018, 08:09 AM
Newbie Group: Members Posts: 13 Joined: 25-July 18 From: Grand Rapids Mi Member No.: 22,337 Region Association: None |
Good afternoon!
First of all let me start off by saying thanks for all your help. Over the past decade I have been on several different car forums and this has been by far the most supportive and accepting group. Thank you. I come from the honda wordl where we are rarely putting in engines from different makes. I grew up on Porsches watching my dad road race in his 912. This is my first porsche and I am stoked to start this project. I am a boost adtict and I am quite confindent that the ej20 it the motor I want to move forward with. I have spent the past 2 weeks searching different builds. I think the hardest choice is detirmining weather I want to use the stock trans or use the subi trans. I am hoping you all could help me sort what options I have in regards to conversion kits kennedy, renegade, ect. Vs. conversion craddles that allow for the subi 5MT. I will most likely purchase a donor car or complete engine/trans/wiring harness ect. So let take the cost of the motor out. Coversion Kit / with stock trans Renegade has their kit priced at 2000 What is the cost of Kennedy Perfomace Kit? Used conversion Kits- Are they round and what do they go for? Conversion with subi 5MT FWD conversion 100-200 Internal Dif delete -75 Craddle Options? Is cold water sill in business Does anyone else make a custom craddle for this swap? Axle Options and Cost? Shifting options and linkage? Thanks in advance. My gut is tellingme to do the full 5MT swap in the process but all the custom craddle fabrication intimidates. |
914forme |
Aug 6 2018, 11:54 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
MT5
Donor Car Stock Subaru ECU with Cobb Tune if you need a bit more and or maybe E85 I would just look for the WRX with a 5 speed manual, that got stuffed in the rear. Buy it, strip it, take what you need, might need, want, desire, and move on. Many a good swap in here, Scott's swap is most likely the closest one to your goal if using the stock ECU. EZ would be Kent 76-914 who responded to this thread EG would be Chris JRust build started which you found |
Lo-Fi Version | Time is now: 16th June 2024 - 08:12 AM |
