| theer |
Aug 10 2018, 08:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States
My driver's side sun visor has a habit of working itself loose from the outside (left) mount.
I've remounted it several times, making sure the pin in set all the way into the mounts on both sides (and the square post properly oriented). But, if I tighten the screw holding the pin in tight enough to prevent the visor from drooping, moving the visor up and down sloooowly works the pin out of its mooring. Anyone else had this problem and has found a fix? Thanks, Tom |
| Chris914n6 |
Aug 10 2018, 01:31 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,534 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Is the pin coming out of the mount or the visor? Pin should be stuck in the mount and the visor is too wide to fall out.
theer Sun visor Aug 10 2018, 08:32 AM
mgphoto Just tighten the screws enough to move the visors ... Aug 10 2018, 08:49 AM
theer yup - that's what I've been doing. It tak... Aug 10 2018, 09:00 AM
mgphoto If that is the case, you need to replace the visor... Aug 10 2018, 10:46 AM
drem914
If that is the case, you need to replace the viso... Aug 10 2018, 10:52 AM
Bartlett 914 I had the same problem. I made new pins with a sho... Aug 10 2018, 11:55 AM
Rob-O
Is the pin coming out of the mount or the visor? ... Aug 10 2018, 02:04 PM
theer I do have the early chrome pins.
Rob - that is ex... Aug 10 2018, 03:48 PM
Robnxious
Rob - that is e... Aug 10 2018, 04:35 PM
Chris914n6
Rob - that is e... Aug 11 2018, 02:32 PM
DaveO90s4 I have this same problem. Am thinking of gluing a ... Aug 10 2018, 04:43 PM
bandjoey Miley 914 rubber might sell the new clips. Check ... Aug 11 2018, 02:12 PM
BENBRO02 I used epoxy to attach the metal pins to the mount... Aug 11 2018, 02:33 PM
mgphoto I would check for lubricant in the visor, use a q-... Aug 11 2018, 03:52 PM
Perry Kiehl 1/8" roll pin/spring pin. Drill through the ... Aug 12 2018, 01:28 PM
ClayPerrine I have super glued the pins in. We replaced the c... Aug 12 2018, 04:00 PM
DaveO90s4 See my post 11 above. All works well - tube is a v... Aug 21 2018, 12:02 AM
theer Thanks for all the responses. I haven't tried... Aug 21 2018, 08:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 07:08 PM |
