| Rusty |
Aug 11 2018, 03:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 7,993 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States
Maybe (probably) this has been done in the last ten years. But I'd like to improve my rear lights.
Two things: 1. Are reasonably priced rear lenses available? I gave away a NOS set a while back... not my best decision, but not my worst. 2. I'd like to improve the lighting in general. My thoughts are that the 40+ year old reflective paint inside could use brightening. Also, LED technology has gone a long way. Do we have any lessons learned on either? thanks, Rusty |
| 7TPorsh |
Aug 15 2018, 12:08 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
I put an led panel behind the reflector and wired to the brake. Light shines through pretty bright.
Easy and doubled the brake light output. Have to get a picture and post. |
Rusty Improving tail lights Aug 11 2018, 03:56 PM
Coondog Spokeworksled.com
Best upgrade for lighting out t... Aug 11 2018, 04:07 PM
Spokeworksled.com
Best upgrade for lighting out ... Aug 11 2018, 04:14 PM
malcolm2
Spokeworksled.com
Best upgrade for lighting out... Aug 15 2018, 12:33 PM
ValcoOscar
Spokeworksled.com
Best upgrade for lighting out ... Aug 15 2018, 08:52 AM
bandjoey on the cheap, LED replacement bulbs. backup is br... Aug 11 2018, 06:13 PM
ClayPerrine Rusty,
Do you want me to bring you a can of chrom... Aug 11 2018, 06:33 PM
The Cabinetmaker Wow! Welcome voice from the past! Aug 11 2018, 06:39 PM
Rusty
Hey m... Aug 15 2018, 06:02 AM
ClayPerrine
Hey ... Aug 15 2018, 09:08 AM
Rusty
[quote name='Rusty' post='2638991' date='Aug 15 2... Aug 15 2018, 09:09 AM
Rand I don't know what it is, but it's stronger... Aug 11 2018, 06:41 PM
The Cabinetmaker Hmmm, does it sit in the console? Aug 15 2018, 06:40 AM
Rusty
:) Aug 15 2018, 09:06 AM
Jett For chroming platic taillights I use http://gcartr... Aug 15 2018, 08:47 AM
ConeDodger Spokeworks... Aug 15 2018, 09:34 AM
7TPorsh I put an led panel behind the reflector and wired ... Aug 15 2018, 12:08 PM
oakdalecurtis Here's what LED strip behind reflector plus th... Aug 15 2018, 01:16 PM
ValcoOscar
Here's what LED strip behind reflector plus t... Aug 15 2018, 01:40 PM
Spoke If you decide to use bulbs or LEDs that use the re... Aug 15 2018, 06:44 PM
RickS Added SuperBright 1157 LEDs as brake lights and th... Aug 15 2018, 10:55 PM
Spoke
Added SuperBright 1157 LEDs as brake lights and t... Aug 16 2018, 10:20 PM
914forme Add a resistor pigtail. Male Spade on one end, fe... Aug 16 2018, 05:46 AM
Rusty Hey fellas, thanks for all the feedback.
The LED ... Aug 16 2018, 11:42 AM
malcolm2
The LED... Aug 16 2018, 07:44 PM
Mblizzard After seeing this I pulled the trigger on the Spok... Aug 16 2018, 12:52 PM
malcolm2
After seeing this I pulled the trigger on the Spo... Aug 16 2018, 07:42 PM
Mblizzard
After seeing this I pulled the trigger on the Sp... Aug 17 2018, 06:25 AM
bandjoey Step 1. $10 HF Dremel tool with needle size g... Aug 17 2018, 06:49 PM
campbellcj Another "ditto" post but FWIW I put LED ... Aug 17 2018, 08:11 PM
7TPorsh Actually referring to this reflector. LED behind h... Aug 18 2018, 05:24 PM
bandjoey
Actually referring to this reflector. LED behind ... Aug 18 2018, 06:13 PM
ClayPerrine
Actually referring to this reflector. LED behind... Aug 19 2018, 07:41 AM
7TPorsh
[quote name='bandjoey' post='2640214' date='Aug 1... Aug 19 2018, 10:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 02:36 AM |
