> Sun visor, keeps falling down
theer
post Aug 10 2018, 08:32 AM
My driver's side sun visor has a habit of working itself loose from the outside (left) mount.
I've remounted it several times, making sure the pin in set all the way into the mounts on both sides (and the square post properly oriented). But, if I tighten the screw holding the pin in tight enough to prevent the visor from drooping, moving the visor up and down sloooowly works the pin out of its mooring.
Anyone else had this problem and has found a fix?
Thanks,
Tom
DaveO90s4
post Aug 21 2018, 12:02 AM
See my post 11 above. All works well - tube is a very tight press fit over OEM shaft. About 6-8 mm long, two per visor. Added a washer between tube added and where that would otherwise rub on sun visor material. Used thin plastic tubing (like the stuff I use for break bleeding).
Cheers
DaveO
theer   Sun visor   Aug 10 2018, 08:32 AM
mgphoto   Just tighten the screws enough to move the visors ...   Aug 10 2018, 08:49 AM
theer   yup - that's what I've been doing. It tak...   Aug 10 2018, 09:00 AM
mgphoto   If that is the case, you need to replace the visor...   Aug 10 2018, 10:46 AM
drem914   If that is the case, you need to replace the viso...   Aug 10 2018, 10:52 AM
Bartlett 914   I had the same problem. I made new pins with a sho...   Aug 10 2018, 11:55 AM
Chris914n6   Is the pin coming out of the mount or the visor? P...   Aug 10 2018, 01:31 PM
Rob-O   Is the pin coming out of the mount or the visor? ...   Aug 10 2018, 02:04 PM
theer   I do have the early chrome pins. Rob - that is ex...   Aug 10 2018, 03:48 PM
Robnxious   I do have the early chrome pins. Rob - that is e...   Aug 10 2018, 04:35 PM
Chris914n6   I do have the early chrome pins. Rob - that is e...   Aug 11 2018, 02:32 PM
DaveO90s4   I have this same problem. Am thinking of gluing a ...   Aug 10 2018, 04:43 PM
bandjoey   Miley 914 rubber might sell the new clips. Check ...   Aug 11 2018, 02:12 PM
BENBRO02   I used epoxy to attach the metal pins to the mount...   Aug 11 2018, 02:33 PM
mgphoto   I would check for lubricant in the visor, use a q-...   Aug 11 2018, 03:52 PM
Perry Kiehl   1/8" roll pin/spring pin. Drill through the ...   Aug 12 2018, 01:28 PM
ClayPerrine   I have super glued the pins in. We replaced the c...   Aug 12 2018, 04:00 PM
DaveO90s4   See my post 11 above. All works well - tube is a v...   Aug 21 2018, 12:02 AM
theer   Thanks for all the responses. I haven't tried...   Aug 21 2018, 08:01 AM
- Lo-Fi Version Time is now: 30th April 2026 - 08:04 PM
