> Trickle charger questions
bandjoey
post Jan 19 2019, 09:53 PM
bandjoey
I've used this HF battery trickle charger for several years. Plug it in and forget it for weeks at a time. Very low and slow charge.rate. Then one day my battery, coil, and pertronics all fried at the same time while out on the road.
The shop said never use a trickle charger for more than 6 hours a day. They said no one really knows why everything went out at once and the long term use of this charger was possibly the cause.
Sometimes the car sits up to 2 weeks without driving it.
If I pick up a new charger do you think it should it be used for just a few hours at a time?
Will a different brand be better for our cars and how long should it be connected to the battery?
If I don't use a trickle charger how long do I need to drive the car to top off the battery?
Valy
post Jan 20 2019, 02:05 AM
The charger can't fry your coil, ignition since the key switch is off. It may damage the battery but only if the charger goes bad. And the type of damage to the battery will cause it to lose max voltage.
bandjoey   Trickle charger questions   Jan 19 2019, 09:53 PM
mepstein   I know many people who use trickle chargers on the...   Jan 19 2019, 10:08 PM
UROpartsman   I use this one. Works great. X2, Battery Tender fl...   Jan 21 2019, 12:50 PM
Mark Henry   If you want to leave it on all the time you need a...   Jan 19 2019, 10:10 PM
mepstein   Someone who understands electronics (not me) can p...   Jan 19 2019, 10:10 PM
bandjoey   What is the difference in a Battery Tender and a S...   Jan 19 2019, 11:01 PM
PlaysWithCars   I used to use a Harbor Freight trickle charger unt...   Jan 20 2019, 01:51 AM
Valy   The charger can't fry your coil, ignition sinc...   Jan 20 2019, 02:05 AM
TravisNeff   I use a NOCO Genius smart charger https://www.ama...   Jan 20 2019, 06:05 AM
Rleog   You might also consider CTEK smart trickle charger...   Jan 20 2019, 06:43 AM
Olympic 914   You might also consider CTEK smart trickle charge...   Jan 20 2019, 09:52 AM
campbellcj   I use a Porsche-branded CTEK (mostly on other cars...   Jan 20 2019, 08:00 AM
Mark Henry   I've used a bunch of CTEKs, many 996 customers...   Jan 20 2019, 10:20 AM
bandjoey   .75a 1.1a 3.5a. ? What size is best for the...   Jan 20 2019, 10:42 AM
Amphicar770   I keep several card on a multi-line smart battery ...   Jan 20 2019, 11:49 AM
Tom_T   Bill - as others have said - 1. For long term st...   Jan 20 2019, 12:53 PM
branston   I have a few of these Schumacher maintainers attac...   Jan 20 2019, 01:07 PM
Big Len   If you're not using the car for 2 weeks at mos...   Jan 20 2019, 02:03 PM
r_towle   Smart charger will charge till full, then shut off...   Jan 20 2019, 11:13 PM
bandjoey   thanks for all the info. since I'm a shade tr...   Jan 21 2019, 03:53 PM
amfab   I get so paranoid that when I use a trickle charge...   Jan 21 2019, 04:17 PM
Rand   I abide by the smart charger rules. One question: ...   Jan 21 2019, 04:25 PM
tmc914   [quote If I don't use a trickle charger how l...   Jan 21 2019, 09:40 PM
thelogo   [quote If I don't use a trickle charger how ...   Jan 24 2019, 04:09 AM
mepstein   You could always take your battery with you when y...   Jan 21 2019, 10:03 PM
90quattrocoupe   I use this one. I got 10 years out of my trailer ...   Jan 23 2019, 08:58 PM
PlaysWithCars   I use this one. I got 10 years out of my trailer...   Jan 24 2019, 12:27 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:29 PM
