| jfort |
Jan 27 2019, 05:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,188 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
I have after market oil lines with AN fittings. The line from the tank to the cooler has a leak. Apparently at the cooler end. As I think about replacing the line, I’ve been thinking about putting in a fitting at the tank end with a valve or a threaded hole for a drain plug. Something to make draining the oil easier than disconnecting the hose. Anyone here ever done such a thing?
| MoveQik |
Jan 28 2019, 01:32 PM
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,667 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I have the same set up as Mepstein and it has worked perfectly for 12 years :-)
| mepstein |
Jan 28 2019, 01:54 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I have the same set up as Mepstein and it has worked perfectly for 12 years :-) I copied the setup from someone. Ive read your build thread many times so it might have been you. (IMG:style_emoticons/default/beerchug.gif) |
jfort Six - Oil Lines Jan 27 2019, 05:17 PM
mepstein Sorry, pic is turned sideways. An next time I drai... Jan 27 2019, 05:23 PM
mb911 The lines I sell have a union in the middle of the... Jan 27 2019, 05:42 PM
porschetub
The lines I sell have a union in the middle of th... Feb 7 2019, 01:24 PM
gms As confident as I am that I would never leave a va... Jan 27 2019, 07:42 PM
Mark Henry A Tee with an EZ drain would be the best.
But...ev... Jan 27 2019, 08:14 PM
But...e... Jan 27 2019, 10:26 PM
gereed75 A simple solution is to drill a hole in the union ... Jan 27 2019, 10:00 PM
GeorgeRud The factory solution with a connection at the oil ... Jan 28 2019, 09:43 AM
Mark Henry
The factory solution with a connection at the oil... Jan 28 2019, 01:25 PM
mb911 I have also made tanks with 911 drains before .. T... Jan 28 2019, 09:56 AM
targa72e I have -16 lines and used this between the line to... Jan 28 2019, 03:16 PM
infraredcalvin I saw somewhere somebody (maybe elephant racing?) ... Jan 29 2019, 12:01 AM
jd74914
I saw somewhere somebody (maybe elephant racing?)... Jan 29 2019, 07:49 AM
infraredcalvin Ahh yes, here it is...
https://www.elephantracing... Jan 29 2019, 12:03 AM
sixnotfour I just uncouple the oil lines...not in a hurry Jan 29 2019, 12:09 AM
jfort Hose taken to hose maker. It was leaking at the co... Feb 1 2019, 08:46 AM
Cairo94507 I would like to add a drain fitting in my oil line... Feb 1 2019, 09:13 AM
Mark Henry My solution. :) Feb 1 2019, 12:41 PM
jfort New line I had made is ready to go in
Feb 6 2019, 04:07 PM
:beer2... Feb 6 2019, 04:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:41 AM |
