e-brake handle assembley removal, how do you do it without affecting current set up?t |
drem914 |
Feb 25 2019, 10:32 AM
Senior Member Group: Members Posts: 1,033 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
I am in the process of installing the vinyl and carpet kits from 914Rubber, but need to remove the e-brake to remove the old carpet and install the new one. What is the process without affecting the other connections back at the rear of the car? Is there any special tricks to removing the handle assembly and not play around with the settings at the back brake?
TIA |
drem914 |
Feb 25 2019, 10:44 AM
I am in the process of installing the vinyl and carpet kits from 914Rubber, but need to remove the e-brake to remove the old carpet and install the new one. What is the process without affecting the other connections back at the rear of the car? Is there any special tricks to removing the handle assembly and not play around with the settings at the back brake? TIA Sorry, did not do a search, looks like the topic is covered quite a bit. Where should the cable be disconnected and how? |
Lo-Fi Version | Time is now: 10th June 2024 - 10:24 AM |
