> Six conversion value for insurance?
Mark Henry
post Mar 29 2019, 07:31 PM
that's what I do!
Just wondering what value we should be putting on /6 conversions these days? (IMG:style_emoticons/default/unsure.gif)
My teen, if it was still a /4, I wouldn't even consider an offer under $25K Canadian, so about $18-19K USD. Not that I want to sell.
/6 core prices are way way up, and so are running engines, What about a fresh performance build?. I used to tell customers a conversion would run $30K (CAD) with engine. but I seriously doubt I could do that now.
My teen is a '74 (1.8 base) paint is (guessing) a 30 yr/old respray colour change, a 7/10 from chips and scratches only, but perfect OG body, perfect interior, Evil tranny, 5-bolt, fuchs , bilsteins, front suspension, etc
Engine 3.0, 2K miles, twinplug/MSD, webers, custom mahle pistons, web cams, fresh build, alumimum tank, etc
No clue what the replacement value for insurance would be..... (IMG:style_emoticons/default/confused24.gif)
What do you think your /6 conversion is worth?
Mark Henry
post Mar 31 2019, 07:09 AM
that's what I do!
So here's my build sheet for 3.0 1974 914 six conversion, what's the engine and the rest of the drivetrain worth?
The build was well documented here's the thread http://www.914world.com/bbs2/index.php?act...=0#entry1993833
Engine 3.0L, 70.4mm X 95mm, 10.5: 1 CR
Case, 1979, 3.0, serial # *6399XXX, 930/13, 930.101.104.4R, Supertec head studs
Crank, stock, std/std, polished and magnafluxed, converted to CW distributor drive gear.
Rods, stock, rebuilt big and small end, new bushings, ARP bolts and nuts.
Flywheel stock lightened, with custom 914-901 adapter ring, CSP 228mm bus HD pressure plate.
Full engine balance, pressure plate and adapter ring balanced separately and as a full complete assembly.
Main bearings, new glyco, DFL (Dry Film Lube) coated.
#8 Main bearing, original Porsche, DFL coated.
Rod bearings, new glyco, DFL coated.
Intermediate shaft bearings, new Porsche, DFL coated.
Gasket set, new nose and rear main seal, Supertec sealant kit.
Pump, stock, cooler stock 911 modified to 914/6 spec.
Pistons, Mahle, new, 3.0 custom RSR style, 10.5:1 CR, DFL coated skirts, ceramic coated tops, Goetze rings.
Cylinders, stock 3.0 nickasil, replated Milenium/LN engineering, stock gaskets, .025mm base gasket.
Heads, 3.0 big port, port work, twin plug.
Valves, stock size, exhaust new TRW sodium, intake new AE.
Valve springs, Eibach sport, retainers early stock, keepers stock modified
Ceramic chambers and exhaust ports.
Cams, WEB-CAM, 120/104, set at 5.2mm/.10 lash, 964 cores modified to 901 spec.
Towers, spray bars R&R, tapped and cleaned, rockers resurfaced, RSR rocker shaft seals.
Chains, new IWIS, new cam sprockets, keys and pins.
Tensioners, hydraulic, no fail modification.
906 style cylinder cooling deflectors.
Cooler, stock, 3.0, modified for 914.
Oil tank, DWD, aluminum, with console and neck
Custom breather tank and OE hose.
Oil, Brad Penn break in, Delo 400 15w40
Carburetors, Weber 40mm IDA, rebuilt, new carb kits, 34mm venturies, 135 main jets, F3 emulsion tubes, 180 air correction, 55 idle, Ported stock manifolds, custom phenolic spacers.
K&N filters and rain hats, Weber linkage
Walbro fuel pump and PMO regulator.
Distributor, PMS/Jarvis, CW, MSD internals, Jaguar XJS-12 cap (1989-1996), Jarvis rotor (RSR clone)
Plug wires custom labled twin plug, Patrick Motorsports
Ignition, MSD 6AL, twin MSD high vibration coils, max RPM 6800
Spark plugs, NGK BPR5ES (BPR6ES also available for tuning)
Headers, 914, 1-1/2” MSDS, ceramic coated
Muffler/collector Magnaflow custom stainless steel 2-1/2”
WMS O2 meter, wideband
Transmission
914, 901, side shift rebuilt, using good used parts
Gasket set, Elring
Gearing, custom, A,F,O,X, HB
Stub axles 108mm 911/901
Spare 2nd rebuilt transmission with stock 914/4 gearing
Axles, Sway-Away custom, part# 2420 directional L and R mark to the outside
CV, Lobro, G50 108mm modified to '1969-1974 spec grease seals
Rear hubs and stubs, 5-bolt Porsche,1972 911, new bearings
Bilstien, shocks, 140lb springs
Front struts, 914/6, Bilstien struts, 5-bolt hubs,
Turbo tie rods, ball joints, and bearings all new German.
Free Motion needle bearings for the front, Original Customs
Sway bars, Tarett front and stock rear
Front calipers, Brembo aluminum, Alpha Romeo GTV-6/Milano (1984-86), rebuilt with 911M kits
Front pads, 1971-72 bus modified,
Front rotor stock vented 914/6, drilled
Rear calipers, PMB V-calipers, stock 914/4 modified for vented rotor, stock rear pads.
Rear rotor stock vented 911, diameter reduced 5mm (10mm total)
Fuchs 1975 “020” 5-bolt Porsche refinished
Spare 944 turbo "outlaw" space saver,
Mark Henry   Six conversion value for insurance?   Mar 29 2019, 07:31 PM
Dion   Mark I have American Collectors Insurance I put a...   Mar 29 2019, 07:40 PM
worn   Just wondering what value we should be putting on...   Mar 29 2019, 07:42 PM
Mark Henry   :agree: I'm more worried about the other guy...   Mar 29 2019, 07:51 PM
mepstein   When I built custom bikes at the bike shop, I woul...   Mar 29 2019, 08:30 PM
mlindner   Mark, mine is in the last stage of assembly. Two y...   Mar 30 2019, 05:25 AM
mepstein   Mark, mine is in the last stage of assembly. Two ...   Mar 30 2019, 06:31 AM
worn   Mark, mine is in the last stage of assembly. Two ...   Mar 30 2019, 04:42 PM
defianty   I've currently only got mine insured for 25K U...   Mar 30 2019, 07:11 AM
scallyk9   My '74 3.2L conversion is insured with Hagerty...   Mar 30 2019, 10:44 AM
daytona   I have my 74 with 3.0L insured with Hagerty for 45...   Mar 30 2019, 02:30 PM
raynekat   Get a professional appraisal...period. Someone wh...   Mar 30 2019, 03:31 PM
thelogo   Conversion 50 k As those can be replaced You coul...   Mar 30 2019, 03:48 PM
mepstein   Conversion 50 k As those can be replaced You cou...   Mar 30 2019, 04:30 PM
thelogo   Conversion 50 k As those can be replaced You co...   Mar 31 2019, 07:35 AM
EdwardBlume   It’s not how much it’s worth, it’s how much ...   Mar 30 2019, 04:14 PM
DickSteinkamp   It’s not how much it’s worth, it’s how much...   Mar 31 2019, 10:05 AM
dr914@autoatlanta.com   any decent six conversion (genuine five lug conver...   Mar 30 2019, 04:29 PM
larryM   any decent six conversion ... Nice paint and inte...   Apr 2 2019, 02:42 PM
Larmo63   My '73 2.4S conversion narrow body hot rod is ...   Mar 30 2019, 07:13 PM
RickS   Only have mine at 30K agreed value. The conversion...   Mar 30 2019, 10:24 PM
Mark Henry   So here's my build sheet for 3.0 1974 914 six ...   Mar 31 2019, 07:09 AM
mepstein   Most of the big names charge $20-30k for a fu...   Mar 31 2019, 07:34 AM
Mark Henry   Like I said, the only way to get a true replacem...   Mar 31 2019, 08:00 AM
mepstein   Like I said, the only way to get a true replace...   Mar 31 2019, 09:08 AM
ConeDodger   I think $50K is the floor. The ceiling is whe...   Mar 31 2019, 09:32 AM
wobbletop   I put mine at $65K canadian. Better safe than...   Mar 31 2019, 10:41 AM
Mark Henry   I believe a 917 was $35k from the factory in...   Mar 31 2019, 11:28 AM
mepstein   I believe a 917 was $35k from the factory i...   Mar 31 2019, 11:40 AM
wobbletop   Who with? Hagerty? Cripes by that metric I'm...   Mar 31 2019, 01:17 PM
horizontally-opposed   Correct. The last time I asked here, the consensu...   Mar 31 2019, 10:47 PM
Mark Henry   The other issue if the wife finds out what it...   Mar 31 2019, 11:50 AM
horizontally-opposed   The other issue if the wife finds out what it...   Mar 31 2019, 10:43 PM
jagalyn   The other issue if the wife finds out what it...   Apr 1 2019, 01:34 AM
Coondog   Currently have mine at 50k, and will be raising it...   Mar 31 2019, 12:35 PM
jagalyn   They say 'buy the best one you can afford...   Apr 1 2019, 07:36 AM
horizontally-opposed   They say 'buy the best one you can afford...   Apr 1 2019, 10:16 AM
mepstein   Never sell.   Apr 1 2019, 07:38 AM
jagalyn   Never sell. Yep... should have told me that 25 ...   Apr 1 2019, 07:42 AM
MoveQik   I have an agreed upon value with Hagerty of ...   Apr 1 2019, 09:54 AM
mb911   So I wonder what I should insure my project for? I...   Apr 1 2019, 10:19 AM
mepstein   So I wonder what I should insure my project for? ...   Apr 1 2019, 11:02 AM
Mark Henry   So I wonder what I should insure my project for?...   Apr 1 2019, 08:51 PM
mepstein   [quote name='mepstein' post='2701699' date='Apr 1...   Apr 1 2019, 09:01 PM
Mark Henry   [quote name='mepstein' post='2701699' date='Apr ...   Apr 1 2019, 09:06 PM
mepstein   [quote name='mepstein' post='2701843' date='Apr 1...   Apr 1 2019, 09:27 PM
JRust   With insurance like you said. IT isn't what yo...   Apr 1 2019, 09:51 PM
roblav1   Concur at least $50k US for a good 6 conversi...   Apr 2 2019, 09:38 AM
Mark Henry   Concur at least $50k US for a good 6 convers...   Apr 2 2019, 10:39 AM
roblav1   JE 9.5:1. This engine has the lighter 2.7 6 bolt ...   Apr 2 2019, 10:59 AM
Retroracer   My Insurance renewal came up last month; but this ...   Apr 2 2019, 11:43 AM
mepstein   A Singer is just a modified 964. 964 vin. If it ge...   Apr 2 2019, 03:14 PM
11tenths   What's the purpose of having insurance- is it ...   Apr 2 2019, 03:17 PM
thelogo   - spend some time on Patrick Motorsports' site...   Apr 5 2019, 04:18 PM
bbrock   FYI, I just bought a Hagerty policy yesterday for ...   Apr 3 2019, 07:08 PM
11tenths   They should call it "Jackstand Insurance...   Apr 4 2019, 10:07 AM
Chris914n6   I just did a spreadsheet for mine. Started with th...   Apr 4 2019, 12:01 PM
Mark Henry   I just did a spreadsheet for mine. Started with t...   Apr 5 2019, 04:11 PM
thelogo   https://orangecounty.craigslist.org/cto/d/o...6858...   Apr 6 2019, 12:42 PM
larryM   just did a search on 914/6 values - since 2012 it ...   Apr 13 2019, 12:51 PM
Mark Henry   Appraised, insurance, build receipts and selling p...   Apr 14 2019, 07:27 AM
sharper   Sounds like I have mine under insured compared to ...   Apr 16 2019, 09:58 AM
mzapisek   I just bumped mine up from 35K to 60K with Hagerty...   Apr 16 2019, 10:06 AM
dwelle   i have a thread going over on pelican regarding va...   Aug 8 2019, 01:47 PM
thelogo   Agreed value is the way . Insurance co dont give...   Aug 8 2019, 05:50 PM
horizontally-opposed   ^ Agree with those who say agreed value is the way...   Aug 8 2019, 06:21 PM
Coondog   Your policy cost is based on the value that you st...   Aug 8 2019, 06:25 PM
rgalla9146   Hagerty agreed to 50K on my conversion without an...   Aug 9 2019, 05:30 AM
mepstein   You need to insure it for what a good shop would c...   Aug 9 2019, 08:28 AM
Mark Henry   You need to insure it for what a good shop would ...   Aug 9 2019, 03:59 PM
mepstein   You need to insure it for what a good shop would...   Aug 9 2019, 05:57 PM
Mark Henry   [quote name='Mark Henry' post='2736835' date='Aug...   Aug 10 2019, 06:59 AM
Cairo94507   I agree agreed upon value is the only way to go. ...   Aug 9 2019, 08:55 AM
- Lo-Fi Version Time is now: 23rd December 2025 - 07:00 PM
