perfect fit tail lights and tail light bodies are here, we are happy to finally get them |
dr914@autoatlanta.com |
Aug 1 2019, 02:15 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
these fit and look great, finally a solution to the old tail light bodies and now perfect fit lenses as well [attachmentid=706
970] Attached thumbnail(s) |
raynekat |
Aug 3 2019, 05:29 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I agree George....most used housings I've seen are toast. Many times people put in the wrong bulb that's too hot and end up melting the housing. Or the corners have been broken off. Or the rubber seal between the housing and the body goes bad, they leak water, instead of replacing the seal, people tighten the bejeezus out of the housing and end up cracking or tweeking the housing so that's it's ruined. I'd say those that just need the reflector are definitely in the minority.
Happy you are offering the entire assembly. I'll be buying a set soon to see how they look and fit. |
bbrock |
Aug 3 2019, 06:19 PM
I agree George....most used housings I've seen are toast. Many times people put in the wrong bulb that's too hot and end up melting the housing. Or the corners have been broken off. Or the rubber seal between the housing and the body goes bad, they leak water, instead of replacing the seal, people tighten the bejeezus out of the housing and end up cracking or tweeking the housing so that's it's ruined. I'd say those that just need the reflector are definitely in the minority. Happy you are offering the entire assembly. I'll be buying a set soon to see how they look and fit. I'll take your word. I haven't seen enough to know, but do the repros have this? It would be nice to be able to refurbish OE housings that are worth saving. I also think its great that compete units are being offered, but the notion that replacing reflector assemblies is too difficult is pretty silly considering what so many of us are doing with these cars. I get it if the market doesn't pencil out though. (IMG:style_emoticons/default/beerchug.gif) |
Jett |
Aug 3 2019, 07:00 PM
Senior Member Group: Members Posts: 1,641 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I agree George....most used housings I've seen are toast. Many times people put in the wrong bulb that's too hot and end up melting the housing. Or the corners have been broken off. Or the rubber seal between the housing and the body goes bad, they leak water, instead of replacing the seal, people tighten the bejeezus out of the housing and end up cracking or tweeking the housing so that's it's ruined. I'd say those that just need the reflector are definitely in the minority. Happy you are offering the entire assembly. I'll be buying a set soon to see how they look and fit. I'll take your word. I haven't seen enough to know, but do the repros have this? It would be nice to be able to refurbish OE housings that are worth saving. I also think its great that compete units are being offered, but the notion that replacing reflector assemblies is too difficult is pretty silly considering what so many of us are doing with these cars. I get it if the market doesn't pencil out though. (IMG:style_emoticons/default/beerchug.gif) G-Car (http://gcartrim.com/) will re-chrome the plastic... they re-chrome the early fog lights as well. Btw. George, great looking part! Do you have the housing to body seals that more closely resemble stock? |
Lo-Fi Version | Time is now: 9th June 2024 - 05:27 PM |
