surfdogskier |
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None ![]() |
We just had a car show up here in Pigeon Forge the last couple of weeks. As usual every year, a bunch of cars get stolen. An I mean nice collectables. I would think it would be a no brainer to put some type of theft deterant mechinism on these babies.
What do you guys use on your rides to help make sure your baby is where you parked it when you come out of wherever? Looking for some ideas and details. Thanks, Jason |
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Hidden switches!
Small switches that control fuel pump and spark. As the interior light on 914 is not so good can even use it as the switch. |
surfdogskier |
Hidden switches! Small switches that control fuel pump and spark. As the interior light on 914 is not so good can even use it as the switch. I like the idea using the switch in the interior light hooked to fuel pump....I see you are in Knoxville. I am in Sevierville. |
Unobtanium-inc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,356 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None ![]() ![]() |
Hidden switches! Small switches that control fuel pump and spark. As the interior light on 914 is not so good can even use it as the switch. I like the idea using the switch in the interior light hooked to fuel pump....I see you are in Knoxville. I am in Sevierville. The double trick when doing this is hook the switch to the ground on the fuel pump, no thief ever think of that. Sure they will run a hot lead wire with alligator clips, but no one thinks of a bad ground. My brother did this with his Jetta back in the day, worked great, the first time. The 2nd time the thieves just dragged his car a few block and stripped it. |
Lo-Fi Version | Time is now: 26th September 2025 - 07:22 AM |
