GT Flares Installation |
9146C |
Apr 23 2020, 10:51 AM
Member Group: Members Posts: 228 Joined: 14-September 19 From: US Member No.: 23,460 Region Association: None |
After completing more than 90% of my rustoration projects on the chassis, I am about to start the installation of the GT (metal) flares (AA purchase).
A question for those who have already done this...any tips/tricks/watch-outs or any advice on what you would have done differently? Thanks in advance! |
Garland |
Apr 23 2020, 01:14 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
From 2012 when a bunch of us got flares, the first link has a large list of project links.
Hears a great post I used for referance when installing mine. Lots of links. Great post on install links Heres mine, i reshaped the bottom of each flare, after alining the top center to the car. (if i did it again the only thing I would change, frt's 1/2" more foward) Running 9x16 on all 4 corners. Messure 10 times, and cut 1 time. I fit and welded mine before I had the wheels and tires. I focused strongly on the size of the tire space being equal, and distance from the hubs, using all of the flare, not just the outer look. Welded all 4 on. Then I got the wheel and tire size to fill the rear space. buying the rear set first, using them to check turning clearance on the front. The 9" fit! Got 2 more. Some say fit the flare to the wheel and tire. Using the tire as the guide, this will work also as a starting point. If you know the wheel and tire size you want to use. That was my biggest question. Michigan Build On paint: Great paint guy on you tube "The Gunman" (australian) i learned a lot watching him before I painted. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:26 AM |
