GB Hardware+ - Visor screws + front turn signal lens screws+, Ends Tomorrow 4.30.20 e if you want Plus something you may not have known about the signal cover screws |
Mikey914 |
Apr 8 2020, 02:43 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
First off thanks to those of you that bought my visors. we made some visor screws that are currently of for nickel plating as I write this. This will be ready this next week.
We did also make the front turn signal lens screws. These are an unusual animal in that they are not quite what the appear to be. Did you even notice that they strip out a little easier than most screws? We believe this to be a design feature. Most screws are steel either stainless or carbon with plating on them. If you have an original you will notice it sounds a little different if you drop it on concrete. The reason is that they are made out of aluminum. This is because they were designed to strip out. Yes intended to strip. If they were over tightened. Mechanically you could put much more pressure than you would want onto the lenses with a steel screw. Think about it if you have ever cracked a lens it more than likely was not with the OEM screw in it. I know I have stripped out a few. As these are both small and can easily ship in a small padded envelope we decided to release a few Group Buys together so that you can have some stuff to do and save on shipping The short list Visor screw Reg $5 a set GB price $3.50 for all 4 (note the finish on the screw in the picture is wrong, it is being re plated now. The turn signal screws Red $1.75 each ($7.00 a set) GB price $3.75 a set And if you are planing to replace the screws you can get new lenses at a reduced price Amber set of 2 (reg $24) with screws $12 a set! Clear set of 2 (reg $32) with screws $16 a set! And yes while you are there I do have the new seals too. Yes reg $16.50 a set I can add in for $10 if added in with the screws. This will give you a quick and easy afternoon project and save some cash! So Who's interested? Attached thumbnail(s) Attached image(s) |
fiacra |
Apr 29 2020, 12:43 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 344 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Mark, I need two sets of visor screws, two sets of turn signal screws, and one set of turn signal gaskets.
Thanks! |
Lo-Fi Version | Time is now: 6th June 2024 - 05:44 AM |
