| 913B |
Jul 18 2020, 05:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
If anyone had run into this before or have any helpful tips, it would be appreciated. If not no worries I plan to call their troubleshooting hotline Monday.
I was able to lift a vehicle up then down, didn't really come all the way down but good enough to slide the QJ out and pretty much applied my weight on them to finish going all the way down. Curiosity got the best of me so I lifted them with no weight they both went up. And only one came back down slowly. The other side appears to be stuck and would not come down or up. It is currently stuck in the up position. The thing I have tried is to ensure the side tank was pressurized to 50psi. I tried swapping the hydraulic lines still that one side won't move. The other side works fine up and down. So it seems it's not the lines or the hydraulic unit. But the that particular cylinder? Any thoughts for the weekend. Thanks, everyone! |
| Olympic 914 |
Jul 19 2020, 08:12 AM
![]() ![]() ![]() Group: Members Posts: 1,771 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
Check the air pressure in the cylinders. Mine started acting wonky and the air was low.
I don't remember the pressure, But it will be listed in the manual. Edit. Sorry i didn't see you already checked the pressure...… |
| Robarabian |
Jul 19 2020, 09:14 AM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 739 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
913B Quick Jack Assistance is Needed Please. Jul 18 2020, 05:40 PM
Aualexa1 https://help.quickjack.com/support/solution...ith-... Jul 18 2020, 05:52 PM
Cairo94507 I agree with the weight. When I raise my lift (no... Jul 19 2020, 06:45 AM
pilothyer
15 psi..
Check the air pressure in the cylind... Jul 19 2020, 09:56 PM
Robarabian The instructions say a max of 15... so be careful ... Jul 20 2020, 08:24 AM
pilothyer
The instructions say a max of 15... so be careful... Jul 22 2020, 11:22 AM
914sgofast2 The Quick Jacks need weight on them to come down. ... Jul 19 2020, 09:00 AM
914werke it says specifically in the instructions you must ... Jul 19 2020, 11:35 AM
Coondog Just stand on it while lowering. Jul 19 2020, 11:15 PM
913B I tried stack a set of tire and wheels on it and n... Jul 19 2020, 11:48 PM
drem914
I tried stack a set of tire and wheels on it and ... Jul 20 2020, 07:55 AM
913B
I tried stack a set of tire and wheels on it and... Jul 22 2020, 04:21 PM
Robarabian Put them side by side.. you cant stand on just one... Jul 20 2020, 08:24 AM
913B Hmm my instruction manual says 50 psi max not 15 t... Jul 20 2020, 10:12 AM
KELTY360
Hmm my instruction manual says 50 psi max not 15 ... Jul 20 2020, 10:43 AM
eric9144
Hmm my instruction manual says 50 psi max not 15 ... Jul 20 2020, 01:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:15 AM |
