> Quick Jack Assistance is Needed Please., One side is stuck up
913B
post Jul 18 2020, 05:40 PM
If anyone had run into this before or have any helpful tips, it would be appreciated. If not no worries I plan to call their troubleshooting hotline Monday.
I was able to lift a vehicle up then down, didn't really come all the way down but good enough to slide the QJ out and pretty much applied my weight on them to finish going all the way down. Curiosity got the best of me so I lifted them with no weight they both went up. And only one came back down slowly. The other side appears to be stuck and would not come down or up. It is currently stuck in the up position.
The thing I have tried is to ensure the side tank was pressurized to 50psi.
I tried swapping the hydraulic lines still that one side won't move. The other side works fine up and down. So it seems it's not the lines or the hydraulic unit. But the that particular cylinder?
Any thoughts for the weekend.
Thanks, everyone!
914werke
post Jul 19 2020, 11:35 AM
it says specifically in the instructions you must always have weight on the lifts when raising/lowering them
913B   Quick Jack Assistance is Needed Please.   Jul 18 2020, 05:40 PM
Aualexa1   https://help.quickjack.com/support/solution...ith-...   Jul 18 2020, 05:52 PM
Cairo94507   I agree with the weight. When I raise my lift (no...   Jul 19 2020, 06:45 AM
Olympic 914   Check the air pressure in the cylinders. Mine star...   Jul 19 2020, 08:12 AM
Robarabian   15 psi.. Check the air pressure in the cylinde...   Jul 19 2020, 09:14 AM
pilothyer   15 psi.. Check the air pressure in the cylind...   Jul 19 2020, 09:56 PM
Robarabian   The instructions say a max of 15... so be careful ...   Jul 20 2020, 08:24 AM
pilothyer   The instructions say a max of 15... so be careful...   Jul 22 2020, 11:22 AM
914sgofast2   The Quick Jacks need weight on them to come down. ...   Jul 19 2020, 09:00 AM
914werke   it says specifically in the instructions you must ...   Jul 19 2020, 11:35 AM
Coondog   Just stand on it while lowering.   Jul 19 2020, 11:15 PM
913B   I tried stack a set of tire and wheels on it and n...   Jul 19 2020, 11:48 PM
drem914   I tried stack a set of tire and wheels on it and ...   Jul 20 2020, 07:55 AM
913B   I tried stack a set of tire and wheels on it and...   Jul 22 2020, 04:21 PM
Robarabian   Put them side by side.. you cant stand on just one...   Jul 20 2020, 08:24 AM
913B   Hmm my instruction manual says 50 psi max not 15 t...   Jul 20 2020, 10:12 AM
KELTY360   Hmm my instruction manual says 50 psi max not 15 ...   Jul 20 2020, 10:43 AM
eric9144   Hmm my instruction manual says 50 psi max not 15 ...   Jul 20 2020, 01:53 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:23 PM
