| Mueller |
Dec 16 2004, 10:04 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
for my 2316 it seems that the stock plenum might be reaching it's limits as far as volume goes.....so, I either fabricate a larger common plenum, or go with individual throttle bodies such as TWM or Jenvey*
single plenum would be easiest, but the individual throttle bodies look better (IMG:style_emoticons/default/smile.gif) has anyone switched from one to the other on the same motor with everything else being the same??? *Jake Raby is the U.S. distributor of these.... |
| Aaron Cox |
Dec 18 2004, 05:34 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
QUOTE(SirAndy @ Dec 18 2004, 04:25 PM) as far as *ugly* goes, we all know that beauty is in the eye of the beholder ... (IMG:style_emoticons/default/biggrin.gif) Andy beauty is in the eye of the beer holder (IMG:style_emoticons/default/beerchug.gif) |
Mueller Common plenum or individual runners??? Dec 16 2004, 10:04 PM
lapuwali Biggest problem with IR throttles is getting a goo... Dec 16 2004, 10:18 PM
ottox914 Here is another place to check for FI throttle bod... Dec 16 2004, 10:18 PM
Bleyseng <... Dec 16 2004, 10:41 PM
rdauenhauer Im not smart enough to follow this ... :wacko:
Wh... Dec 16 2004, 10:56 PM
Bleyseng air velocity I think. Under lite vacuum at cruisin... Dec 16 2004, 11:01 PM
Cloudbuster The general gist is short intake runners for high ... Dec 16 2004, 11:10 PM
Mueller Geoff,
Based on another thread in which Jake ment... Dec 16 2004, 11:55 PM
Bleyseng The difference between a 2270 and a 2316 isn't... Dec 17 2004, 12:17 AM
ottox914 My very basic understanding of plenum and runners ... Dec 17 2004, 08:25 AM
Jake Raby Bleyseng,
I have never had ANY engine that I could... Dec 17 2004, 08:54 AM
Bleyseng Jake, I am going with the Megasquirt setup but ret... Dec 17 2004, 09:02 AM
Jake Raby I'm sure he can make it run right, but the que... Dec 17 2004, 09:11 AM
Bleyseng Ok, 'bout how much more Volume do you think it... Dec 17 2004, 09:15 AM
Jake Raby :lol2: Dec 17 2004, 09:41 AM
Mueller
jwalters ... Dec 17 2004, 05:57 PM
Jeroen Mike, do a search on the pelican taildraggers foru... Dec 17 2004, 10:16 PM
Mueller
Qarl http://www.abdgraphics.com/iansite/ianthro...rottl... Dec 17 2004, 11:40 PM
SirAndy <... Dec 18 2004, 02:33 AM
Brett W The common plenum system will make more power than... Dec 18 2004, 08:07 AM
Mueller <... Dec 18 2004, 01:31 PM
Aaron Cox heres a wild thought....use carb manifolds.... wel... Dec 18 2004, 01:42 PM
TimT Mike the GT3RS we just tore down has a big box ple... Dec 18 2004, 02:09 PM
Mueller
Aaron Cox beautiful drawings :trophy:
pony up for the jen... Dec 18 2004, 02:24 PM
Bleyseng Aaron, I was thinking along those lines last night... Dec 18 2004, 03:25 PM
Aaron Cox ... Dec 18 2004, 03:26 PM
SirAndy ... Dec 18 2004, 04:32 PM
Mueller the 3.2 upper might work, my issue with it is that... Dec 18 2004, 05:09 PM
SirAndy <... Dec 18 2004, 05:25 PM
Mueller
RD Evans Here is a link to a custom made manifold that migh... Dec 18 2004, 06:32 PM
Mueller thanks for the link...nice and simple manifold....... Dec 18 2004, 06:39 PM
Bleyseng Hmm, I thought the intake valves on a 3.2l are 49m... Dec 18 2004, 06:49 PM
TimT This guy makes a nifty throttle alternative "barr... Dec 18 2004, 06:54 PM
Mueller pretty damn slick Tim........much easier to seal t... Dec 18 2004, 07:28 PM
DNHunt I can't offer much except that about the only ... Dec 18 2004, 07:50 PM
Air_Cooled_Nut <... Dec 18 2004, 08:29 PM
Jeroen IIRC slide valves only work better at WOT, when th... Dec 18 2004, 08:47 PM
SirAndy ... Dec 18 2004, 09:45 PM
Bleyseng hmmm, that is damn close then. Someone here must k... Dec 18 2004, 11:04 PM
Bleyseng Andy, what size is the 3.2l TB?
65mm TB Dave, damn... Dec 18 2004, 11:16 PM
Brett W The early 90s Honda Prelude which was a 2.0 engine... Dec 19 2004, 12:38 AM
SirAndy ... Dec 19 2004, 12:45 AM
914efi This is what I built for my 2.2E engine. It seems ... Dec 19 2004, 08:37 AM
Mueller 914efi, nice DIY job :trophy:
a couple of quest... Dec 19 2004, 12:21 PM
Brett W Mike,
The slide throttles could work fine on a str... Dec 19 2004, 01:55 PM
Jake Raby I have tested Kit Carlson with I/R on a 2563cc eng... Dec 19 2004, 02:08 PM
Air_Cooled_Nut http://www.91... Dec 20 2004, 08:05 AM
914efi I bought a 3.2 intake on the advice of a local ... Dec 20 2004, 08:55 AM
914efi another view Dec 20 2004, 12:45 PM
Bleyseng Take a look Mueller. Dec 20 2004, 03:30 PM
jwalters Dec 20 2004, 03:54 PM
TimT Mike here is the GT3RS plenum, I couldnt find wher... Dec 20 2004, 04:19 PM
TimT nuther Dec 20 2004, 04:20 PM
TimT YOu bolt the different restrictors to that round ... Dec 20 2004, 04:22 PM
Mueller thanks Tim,
that is a huge plenum...and dusty to... Dec 20 2004, 04:48 PM
TimT
