Common plenum or individual runners???, for gas milage and drivability |
Mueller |
Dec 16 2004, 10:04 PM
for my 2316 it seems that the stock plenum might be reaching it's limits as far as volume goes.....so, I either fabricate a larger common plenum, or go with individual throttle bodies such as TWM or Jenvey*
single plenum would be easiest, but the individual throttle bodies look better (IMG:style_emoticons/default/smile.gif) has anyone switched from one to the other on the same motor with everything else being the same??? *Jake Raby is the U.S. distributor of these.... |
Mueller |
Dec 18 2004, 05:59 PM
QUOTE the multiply TB/one common plenum setup will probably give you faster throttle response but then you have to deal with syncronizing 4 TBs ... hmmmmm, I wonder if a setup like this would make slide-valve throttle bodies work better thru out the entire rpm range???? |
