> Common plenum or individual runners???, for gas milage and drivability
Mueller
post Dec 16 2004, 10:04 PM
914 Freak!
for my 2316 it seems that the stock plenum might be reaching it's limits as far as volume goes.....so, I either fabricate a larger common plenum, or go with individual throttle bodies such as TWM or Jenvey*
single plenum would be easiest, but the individual throttle bodies look better (IMG:style_emoticons/default/smile.gif)
has anyone switched from one to the other on the same motor with everything else being the same???
*Jake Raby is the U.S. distributor of these....
Mueller
post Dec 19 2004, 12:21 PM
914 Freak!
914efi, nice DIY job (IMG:style_emoticons/default/smilie_pokal.gif)
a couple of questions if you don't mind...location of throttle body, I don't see it.....do you have any sort of air-horns or radiused inlets inside the main plenum going to the runners? (if not, this could be an issue if the runners just mate directly to the flat sides of the plenum)
Brett, I know the low speed drivability supposed to suck with slide-valves and barral valves, but it seems that using those with a plenum, some of the problems can be overcome.
Dave,
My MS install on the 1.8 w/2.0 heads and 2.0 plenum and a header pulled 55kPa at idle, I wonder if it was due to the more effeicient heads on the smaller bore motor ???
Now, what material would be best to build the plenum out of??? I'd have to say some sort of plastic or non-metal material so that heat soak does not happen as easily.....time to start hitting those websites to learn how to use and make something from carbon-fiber (IMG:style_emoticons/default/smash.gif)
Mueller   Common plenum or individual runners???   Dec 16 2004, 10:04 PM
lapuwali   Biggest problem with IR throttles is getting a goo...   Dec 16 2004, 10:18 PM
ottox914   Here is another place to check for FI throttle bod...   Dec 16 2004, 10:18 PM
Bleyseng   <...   Dec 16 2004, 10:41 PM
rdauenhauer   Im not smart enough to follow this ... :wacko: Wh...   Dec 16 2004, 10:56 PM
Bleyseng   air velocity I think. Under lite vacuum at cruisin...   Dec 16 2004, 11:01 PM
Cloudbuster   The general gist is short intake runners for high ...   Dec 16 2004, 11:10 PM
Mueller   Geoff, Based on another thread in which Jake ment...   Dec 16 2004, 11:55 PM
Bleyseng   The difference between a 2270 and a 2316 isn't...   Dec 17 2004, 12:17 AM
ottox914   My very basic understanding of plenum and runners ...   Dec 17 2004, 08:25 AM
Jake Raby   Bleyseng, I have never had ANY engine that I could...   Dec 17 2004, 08:54 AM
Bleyseng   Jake, I am going with the Megasquirt setup but ret...   Dec 17 2004, 09:02 AM
Jake Raby   I'm sure he can make it run right, but the que...   Dec 17 2004, 09:11 AM
Bleyseng   Ok, 'bout how much more Volume do you think it...   Dec 17 2004, 09:15 AM
Jake Raby   :lol2:   Dec 17 2004, 09:41 AM
Mueller
  Dec 17 2004, 11:27 AM
jwalters   ...   Dec 17 2004, 05:57 PM
Jeroen   Mike, do a search on the pelican taildraggers foru...   Dec 17 2004, 10:16 PM
Mueller     Dec 17 2004, 11:27 PM
Qarl   http://www.abdgraphics.com/iansite/ianthro...rottl...   Dec 17 2004, 11:40 PM
SirAndy   <...   Dec 18 2004, 02:33 AM
Brett W   The common plenum system will make more power than...   Dec 18 2004, 08:07 AM
Mueller   <...   Dec 18 2004, 01:31 PM
Aaron Cox   heres a wild thought....use carb manifolds.... wel...   Dec 18 2004, 01:42 PM
TimT   Mike the GT3RS we just tore down has a big box ple...   Dec 18 2004, 02:09 PM
Mueller     Dec 18 2004, 02:21 PM
Aaron Cox   beautiful drawings :trophy: pony up for the jen...   Dec 18 2004, 02:24 PM
Bleyseng   Aaron, I was thinking along those lines last night...   Dec 18 2004, 03:25 PM
Aaron Cox   ...   Dec 18 2004, 03:26 PM
SirAndy   ...   Dec 18 2004, 04:32 PM
Mueller   the 3.2 upper might work, my issue with it is that...   Dec 18 2004, 05:09 PM
SirAndy   <...   Dec 18 2004, 05:25 PM
Aaron Cox   <...   Dec 18 2004, 05:34 PM
Mueller
  Dec 18 2004, 05:59 PM
RD Evans   Here is a link to a custom made manifold that migh...   Dec 18 2004, 06:32 PM
Mueller   thanks for the link...nice and simple manifold.......   Dec 18 2004, 06:39 PM
Bleyseng   Hmm, I thought the intake valves on a 3.2l are 49m...   Dec 18 2004, 06:49 PM
TimT   This guy makes a nifty throttle alternative "barr...   Dec 18 2004, 06:54 PM
Mueller   pretty damn slick Tim........much easier to seal t...   Dec 18 2004, 07:28 PM
DNHunt   I can't offer much except that about the only ...   Dec 18 2004, 07:50 PM
Air_Cooled_Nut   <...   Dec 18 2004, 08:29 PM
Jeroen   IIRC slide valves only work better at WOT, when th...   Dec 18 2004, 08:47 PM
SirAndy   ...   Dec 18 2004, 09:45 PM
Bleyseng   hmmm, that is damn close then. Someone here must k...   Dec 18 2004, 11:04 PM
Bleyseng   Andy, what size is the 3.2l TB? 65mm TB Dave, damn...   Dec 18 2004, 11:16 PM
Brett W   The early 90s Honda Prelude which was a 2.0 engine...   Dec 19 2004, 12:38 AM
SirAndy   ...   Dec 19 2004, 12:45 AM
914efi   This is what I built for my 2.2E engine. It seems ...   Dec 19 2004, 08:37 AM
Mueller   914efi, nice DIY job :trophy: a couple of quest...   Dec 19 2004, 12:21 PM
Brett W   Mike, The slide throttles could work fine on a str...   Dec 19 2004, 01:55 PM
Jake Raby   I have tested Kit Carlson with I/R on a 2563cc eng...   Dec 19 2004, 02:08 PM
Air_Cooled_Nut   http://www.91...   Dec 20 2004, 08:05 AM
914efi   I bought a 3.2 intake on the advice of a local ...   Dec 20 2004, 08:55 AM
914efi   another view   Dec 20 2004, 12:45 PM
Bleyseng   Take a look Mueller.   Dec 20 2004, 03:30 PM
jwalters     Dec 20 2004, 03:54 PM
TimT   Mike here is the GT3RS plenum, I couldnt find wher...   Dec 20 2004, 04:19 PM
TimT   nuther   Dec 20 2004, 04:20 PM
TimT   YOu bolt the different restrictors to that round ...   Dec 20 2004, 04:22 PM
Mueller   thanks Tim, that is a huge plenum...and dusty to...   Dec 20 2004, 04:48 PM
TimT     Dec 20 2004, 08:35 PM
Mueller   concrete dust?? that is even worse....... can you...   Dec 20 2004, 10:08 PM
Bleyseng   Check out how short those runners are! Nice ca...   Dec 20 2004, 11:33 PM
Mueller   ...   Dec 21 2004, 12:05 AM
914Timo
  Dec 21 2004, 01:35 AM
McMark   That air box looks like it barely fits in there. ...   Dec 21 2004, 02:44 AM
914efi   I had various ideas on where to put the TB, but wh...   Dec 21 2004, 07:11 AM
914Timo   Very interesting, 914efi. Obviously you have done ...   Dec 21 2004, 08:27 AM
Bleyseng   Mueller, I too after seeing that CF manifold thoug...   Dec 21 2004, 09:12 AM
Jake Raby   My Carbon Fiber tech has been on the plenum for qu...   Dec 21 2004, 09:37 AM
Bleyseng   Ah, but the question here is- Is the carbonfiber m...   Dec 21 2004, 09:54 AM
kwales   Ya know you can tune your intake runner length in ...   Dec 21 2004, 02:21 PM
TimT
  Dec 21 2004, 02:40 PM
Qarl   I don't think the carbon fiber plenum needs to...   Dec 21 2004, 03:37 PM
Mueller     Jan 14 2005, 10:54 AM
Britain Smith   The backfire issue was the reason that Brad and I ...   Jan 14 2005, 11:39 AM
Mark Henry   I can't believe I didn't see this thread b...   Jan 14 2005, 01:31 PM
Mark Henry   If I was going to do an upright, like a DTM, I wo...   Jan 14 2005, 01:36 PM
Mueller
  Jan 14 2005, 01:43 PM
Mueller   more plenum ramblings..... okay....let's say ...   Jan 20 2005, 04:21 PM
lapuwali   <...   Jan 20 2005, 04:41 PM
Bleyseng   Think progressive TB Mike. Lots of them out there ...   Jan 20 2005, 04:49 PM
Mark Henry   James on a T4 with the DTM, that woud be 4 X 28mm ...   Jan 20 2005, 05:23 PM
dinomium   I got this from the 2004 GT3 cup car manual... pre...   Jan 20 2005, 06:14 PM
lapuwali   Somewhat apples and oranges, though. With individ...   Jan 20 2005, 06:28 PM
Bleyseng   Well, you are mixing apples and oranges since carb...   Jan 20 2005, 07:35 PM
lapuwali   ...   Jan 20 2005, 08:21 PM
Jake Raby   Its all in the combo!   Jan 20 2005, 08:25 PM
lapuwali   ...   Jan 20 2005, 09:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:25 AM
