> Common plenum or individual runners???, for gas milage and drivability
Mueller
post Dec 16 2004, 10:04 PM
914 Freak!
for my 2316 it seems that the stock plenum might be reaching it's limits as far as volume goes.....so, I either fabricate a larger common plenum, or go with individual throttle bodies such as TWM or Jenvey*
single plenum would be easiest, but the individual throttle bodies look better (IMG:style_emoticons/default/smile.gif)
has anyone switched from one to the other on the same motor with everything else being the same???
*Jake Raby is the U.S. distributor of these....
jwalters
post Dec 20 2004, 03:54 PM
Sooo Close.......
Region Association: Europe
QUOTE (914efi @ Dec 20 2004, 10:45 AM)
another view
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) wow, thats not bad!!! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
Mueller   Common plenum or individual runners???   Dec 16 2004, 10:04 PM
lapuwali   Biggest problem with IR throttles is getting a goo...   Dec 16 2004, 10:18 PM
ottox914   Here is another place to check for FI throttle bod...   Dec 16 2004, 10:18 PM
Bleyseng   <...   Dec 16 2004, 10:41 PM
rdauenhauer   Im not smart enough to follow this ... :wacko: Wh...   Dec 16 2004, 10:56 PM
Bleyseng   air velocity I think. Under lite vacuum at cruisin...   Dec 16 2004, 11:01 PM
Cloudbuster   The general gist is short intake runners for high ...   Dec 16 2004, 11:10 PM
Mueller   Geoff, Based on another thread in which Jake ment...   Dec 16 2004, 11:55 PM
Bleyseng   The difference between a 2270 and a 2316 isn't...   Dec 17 2004, 12:17 AM
ottox914   My very basic understanding of plenum and runners ...   Dec 17 2004, 08:25 AM
Jake Raby   Bleyseng, I have never had ANY engine that I could...   Dec 17 2004, 08:54 AM
Bleyseng   Jake, I am going with the Megasquirt setup but ret...   Dec 17 2004, 09:02 AM
Jake Raby   I'm sure he can make it run right, but the que...   Dec 17 2004, 09:11 AM
Bleyseng   Ok, 'bout how much more Volume do you think it...   Dec 17 2004, 09:15 AM
Jake Raby   :lol2:   Dec 17 2004, 09:41 AM
Mueller
  Dec 17 2004, 11:27 AM
jwalters   ...   Dec 17 2004, 05:57 PM
Jeroen   Mike, do a search on the pelican taildraggers foru...   Dec 17 2004, 10:16 PM
Mueller     Dec 17 2004, 11:27 PM
Qarl   http://www.abdgraphics.com/iansite/ianthro...rottl...   Dec 17 2004, 11:40 PM
SirAndy   <...   Dec 18 2004, 02:33 AM
Brett W   The common plenum system will make more power than...   Dec 18 2004, 08:07 AM
Mueller   <...   Dec 18 2004, 01:31 PM
Aaron Cox   heres a wild thought....use carb manifolds.... wel...   Dec 18 2004, 01:42 PM
TimT   Mike the GT3RS we just tore down has a big box ple...   Dec 18 2004, 02:09 PM
Mueller     Dec 18 2004, 02:21 PM
Aaron Cox   beautiful drawings :trophy: pony up for the jen...   Dec 18 2004, 02:24 PM
Bleyseng   Aaron, I was thinking along those lines last night...   Dec 18 2004, 03:25 PM
Aaron Cox   ...   Dec 18 2004, 03:26 PM
SirAndy   ...   Dec 18 2004, 04:32 PM
Mueller   the 3.2 upper might work, my issue with it is that...   Dec 18 2004, 05:09 PM
SirAndy   <...   Dec 18 2004, 05:25 PM
Aaron Cox   <...   Dec 18 2004, 05:34 PM
Mueller
  Dec 18 2004, 05:59 PM
RD Evans   Here is a link to a custom made manifold that migh...   Dec 18 2004, 06:32 PM
Mueller   thanks for the link...nice and simple manifold.......   Dec 18 2004, 06:39 PM
Bleyseng   Hmm, I thought the intake valves on a 3.2l are 49m...   Dec 18 2004, 06:49 PM
TimT   This guy makes a nifty throttle alternative "barr...   Dec 18 2004, 06:54 PM
Mueller   pretty damn slick Tim........much easier to seal t...   Dec 18 2004, 07:28 PM
DNHunt   I can't offer much except that about the only ...   Dec 18 2004, 07:50 PM
Air_Cooled_Nut   <...   Dec 18 2004, 08:29 PM
Jeroen   IIRC slide valves only work better at WOT, when th...   Dec 18 2004, 08:47 PM
SirAndy   ...   Dec 18 2004, 09:45 PM
Bleyseng   hmmm, that is damn close then. Someone here must k...   Dec 18 2004, 11:04 PM
Bleyseng   Andy, what size is the 3.2l TB? 65mm TB Dave, damn...   Dec 18 2004, 11:16 PM
Brett W   The early 90s Honda Prelude which was a 2.0 engine...   Dec 19 2004, 12:38 AM
SirAndy   ...   Dec 19 2004, 12:45 AM
914efi   This is what I built for my 2.2E engine. It seems ...   Dec 19 2004, 08:37 AM
Mueller   914efi, nice DIY job :trophy: a couple of quest...   Dec 19 2004, 12:21 PM
Brett W   Mike, The slide throttles could work fine on a str...   Dec 19 2004, 01:55 PM
Jake Raby   I have tested Kit Carlson with I/R on a 2563cc eng...   Dec 19 2004, 02:08 PM
Air_Cooled_Nut   http://www.91...   Dec 20 2004, 08:05 AM
914efi   I bought a 3.2 intake on the advice of a local ...   Dec 20 2004, 08:55 AM
914efi   another view   Dec 20 2004, 12:45 PM
Bleyseng   Take a look Mueller.   Dec 20 2004, 03:30 PM
jwalters     Dec 20 2004, 03:54 PM
TimT   Mike here is the GT3RS plenum, I couldnt find wher...   Dec 20 2004, 04:19 PM
TimT   nuther   Dec 20 2004, 04:20 PM
TimT   YOu bolt the different restrictors to that round ...   Dec 20 2004, 04:22 PM
Mueller   thanks Tim, that is a huge plenum...and dusty to...   Dec 20 2004, 04:48 PM
TimT     Dec 20 2004, 08:35 PM
Mueller   concrete dust?? that is even worse....... can you...   Dec 20 2004, 10:08 PM
Bleyseng   Check out how short those runners are! Nice ca...   Dec 20 2004, 11:33 PM
Mueller   ...   Dec 21 2004, 12:05 AM
914Timo
  Dec 21 2004, 01:35 AM
McMark   That air box looks like it barely fits in there. ...   Dec 21 2004, 02:44 AM
914efi   I had various ideas on where to put the TB, but wh...   Dec 21 2004, 07:11 AM
914Timo   Very interesting, 914efi. Obviously you have done ...   Dec 21 2004, 08:27 AM
Bleyseng   Mueller, I too after seeing that CF manifold thoug...   Dec 21 2004, 09:12 AM
Jake Raby   My Carbon Fiber tech has been on the plenum for qu...   Dec 21 2004, 09:37 AM
Bleyseng   Ah, but the question here is- Is the carbonfiber m...   Dec 21 2004, 09:54 AM
kwales   Ya know you can tune your intake runner length in ...   Dec 21 2004, 02:21 PM
TimT
  Dec 21 2004, 02:40 PM
Qarl   I don't think the carbon fiber plenum needs to...   Dec 21 2004, 03:37 PM
Mueller     Jan 14 2005, 10:54 AM
Britain Smith   The backfire issue was the reason that Brad and I ...   Jan 14 2005, 11:39 AM
Mark Henry   I can't believe I didn't see this thread b...   Jan 14 2005, 01:31 PM
Mark Henry   If I was going to do an upright, like a DTM, I wo...   Jan 14 2005, 01:36 PM
Mueller
  Jan 14 2005, 01:43 PM
Mueller   more plenum ramblings..... okay....let's say ...   Jan 20 2005, 04:21 PM
lapuwali   <...   Jan 20 2005, 04:41 PM
Bleyseng   Think progressive TB Mike. Lots of them out there ...   Jan 20 2005, 04:49 PM
Mark Henry   James on a T4 with the DTM, that woud be 4 X 28mm ...   Jan 20 2005, 05:23 PM
dinomium   I got this from the 2004 GT3 cup car manual... pre...   Jan 20 2005, 06:14 PM
lapuwali   Somewhat apples and oranges, though. With individ...   Jan 20 2005, 06:28 PM
Bleyseng   Well, you are mixing apples and oranges since carb...   Jan 20 2005, 07:35 PM
lapuwali   ...   Jan 20 2005, 08:21 PM
Jake Raby   Its all in the combo!   Jan 20 2005, 08:25 PM
lapuwali   ...   Jan 20 2005, 09:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:03 AM
