| Steve_R |
Oct 3 2020, 11:52 AM
Member ![]() ![]() Group: Members Posts: 68 Joined: 8-August 12 From: San Diego, CA Member No.: 14,777 Region Association: None |
Hi everyone,
About 4 years ago I designed and built a solid state relay board for my 914. I built a few extra ones and you can read all about that HERE. After building those I realized that not everybody wants solid state relays. So, I designed a version that uses the stock electromechanical relays. I started building a batch of 10 and I got distracted with another project. Recently, I had some more time and I completed those. This relay board uses the stock relays for power, heater and fuel pump. There are no provisions for the rear window heater. The relay socket used for the window heater is used to store an extra relay. This board uses an ATC style fuse and has an LED that illuminates when the relay board is supplying power to the fuel pump. This is useful in diagnosing fuel pump issues. The LED illuminates for about 2 seconds when the key is turned on and remains illuminated when the engine is running. I am selling this last batch for $325.00 each. This board does not come with any relays or the voltage regulator. I’ll cover the shipping and sorry, I can’t ship international. Message me if you want one. No need to reply to this post. I will edit this post and remove this section when they are all gone. Okay, with that said, I will not be making any more of these. I will be making this design available to the 914 World Community. I have attached the 3D solid models (in STEP format) to the next post. Also, I attached a PowerPoint (PDF format) that outlines the construction process as well as the sources for all of the parts. There are 3D models for the solid state relay version as well as the stock electromechanical relay version. This design and associated files is completely open source and can be used by anyone for any reason. These boards are designed to be CNC machined from plastic. I used a CNC VMC. However, I think a CNC router would also work. I don’t think a 3D printer would work with the current design. However, I it could easily be modified to work. Attached image(s)
| Mikey914 |
Oct 3 2020, 12:51 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Would be happy to make a large run of these for those that want them and even add relays at a reduced cost.
Thinking keep the cost low znd just do mass production on the machined oarts, maybe do a kit? |
Steve_R New Relay Board Open Source Design Oct 3 2020, 11:52 AM
Steve_R 3D Models.
I am not able to upload cad files to th... Oct 3 2020, 11:58 AM
Steve_R Construction Details. Oct 3 2020, 11:59 AM
DRPHIL914
Would be happy to make a large run of these for t... Oct 3 2020, 12:54 PM
GregAmy
Would be happy to make a large run of these for t... Oct 5 2020, 08:11 AM
johnorm
Would be happy to make a large run of these for t... Oct 6 2020, 11:22 AM
Mikey914
Would be happy to make a large run of these for ... Oct 6 2020, 11:55 PM
Jett How about adding the rear defrost connection? Oct 3 2020, 09:03 PM
Mikey914
Co... Oct 3 2020, 09:57 PM
JeffBowlsby As admirable as this design and effort is, I see a... Oct 3 2020, 09:25 PM
Steve_R
As admirable as this design and effort is, I see ... Oct 3 2020, 10:15 PM
johnorm
As admirable as this design and effort is, I see ... Oct 6 2020, 12:13 PM
raynekat Wish this was available for the 914-6 relay panel ... Oct 4 2020, 10:40 PM
Superhawk996 Would be great to have a the solid state alternati... Oct 5 2020, 06:38 AM
ClayPerrine How hard would it be to make this up to use the st... Oct 5 2020, 08:52 PM
Mikey914 Not too hard to change up, but why? The new relays... Oct 6 2020, 10:46 AM
ClayPerrine
Not too hard to change up, but why? The new relay... Oct 6 2020, 12:02 PM
Mueller While I no longer am using the stock relay board o... Oct 6 2020, 11:29 AM
JeffBowlsby 0.5 mm^2 converts to 20 gage
1.0 mm^2 converts to ... Oct 6 2020, 01:36 PM
johnorm
1.0 mm^2 converts to... Oct 6 2020, 01:54 PM
johnorm
1.0 mm^2 converts t... Oct 6 2020, 02:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th September 2026 - 02:04 PM |
