> New Relay Board Open Source Design, 3D CAD Models and Parts Source
Steve_R
post Oct 3 2020, 11:52 AM
Hi everyone,
About 4 years ago I designed and built a solid state relay board for my 914. I built a few extra ones and you can read all about that
HERE.
After building those I realized that not everybody wants solid state relays. So, I designed a version that uses the stock electromechanical relays. I started building a batch of 10 and I got distracted with another project. Recently, I had some more time and I completed those. This relay board uses the stock relays for power, heater and fuel pump. There are no provisions for the rear window heater. The relay socket used for the window heater is used to store an extra relay.
This board uses an ATC style fuse and has an LED that illuminates when the relay board is supplying power to the fuel pump. This is useful in diagnosing fuel pump issues. The LED illuminates for about 2 seconds when the key is turned on and remains illuminated when the engine is running.
I am selling this last batch for $325.00 each. This board does not come with any relays or the voltage regulator. I’ll cover the shipping and sorry, I can’t ship international. Message me if you want one. No need to reply to this post. I will edit this post and remove this section when they are all gone.
Okay, with that said, I will not be making any more of these. I will be making this design available to the 914 World Community. I have attached the 3D solid models (in STEP format) to the next post. Also, I attached a PowerPoint (PDF format) that outlines the construction process as well as the sources for all of the parts. There are 3D models for the solid state relay version as well as the stock electromechanical relay version.
This design and associated files is completely open source and can be used by anyone for any reason.
These boards are designed to be CNC machined from plastic. I used a CNC VMC. However, I think a CNC router would also work. I don’t think a 3D printer would work with the current design. However, I it could easily be modified to work.
Mikey914
post Oct 3 2020, 12:51 PM
The rubber man
Would be happy to make a large run of these for those that want them and even add relays at a reduced cost.
Thinking keep the cost low znd just do mass production on the machined oarts, maybe do a kit?
DRPHIL914
post Oct 3 2020, 12:54 PM
Dr. Phil
QUOTE(Mikey914 @ Oct 3 2020, 02:51 PM) *
interested
Steve_R   New Relay Board Open Source Design   Oct 3 2020, 11:52 AM
Steve_R   3D Models. I am not able to upload cad files to th...   Oct 3 2020, 11:58 AM
Steve_R   Construction Details.   Oct 3 2020, 11:59 AM
Mikey914   Would be happy to make a large run of these for th...   Oct 3 2020, 12:51 PM
DRPHIL914   Would be happy to make a large run of these for t...   Oct 3 2020, 12:54 PM
GregAmy   Would be happy to make a large run of these for t...   Oct 5 2020, 08:11 AM
johnorm   Would be happy to make a large run of these for t...   Oct 6 2020, 11:22 AM
Mikey914   Would be happy to make a large run of these for ...   Oct 6 2020, 11:55 PM
Jett   How about adding the rear defrost connection?   Oct 3 2020, 09:03 PM
Mikey914   How about adding the rear defrost connection? Co...   Oct 3 2020, 09:57 PM
JeffBowlsby   As admirable as this design and effort is, I see a...   Oct 3 2020, 09:25 PM
Steve_R   As admirable as this design and effort is, I see ...   Oct 3 2020, 10:15 PM
johnorm   As admirable as this design and effort is, I see ...   Oct 6 2020, 12:13 PM
raynekat   Wish this was available for the 914-6 relay panel ...   Oct 4 2020, 10:40 PM
Superhawk996   Would be great to have a the solid state alternati...   Oct 5 2020, 06:38 AM
ClayPerrine   How hard would it be to make this up to use the st...   Oct 5 2020, 08:52 PM
Mikey914   Not too hard to change up, but why? The new relays...   Oct 6 2020, 10:46 AM
ClayPerrine   Not too hard to change up, but why? The new relay...   Oct 6 2020, 12:02 PM
Mueller   While I no longer am using the stock relay board o...   Oct 6 2020, 11:29 AM
JeffBowlsby   0.5 mm^2 converts to 20 gage 1.0 mm^2 converts to ...   Oct 6 2020, 01:36 PM
johnorm   0.5 mm^2 converts to 20 gage 1.0 mm^2 converts to...   Oct 6 2020, 01:54 PM
johnorm   0.5 mm^2 converts to 20 gage 1.0 mm^2 converts t...   Oct 6 2020, 02:15 PM
- Lo-Fi Version Time is now: 28th September 2026 - 02:04 PM
