| Craigers17 |
Oct 12 2020, 04:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 916 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States
I recently replaced the pedal cluster and mc, so I figured I'd replace the clutch cable while the cluster was out. My question is what is the correct setup where the cable mates up with the clutch fork. I'm not sure my original setup was correct, so now I have the cable attached to the fork with the trunion, and then a nut, followed by a lock nut. No nuts before the fork/trunion as seen in the pic. Just want to make sure this is correct.
If not, can someone please advise on how many nuts, washers, lock nuts, etc. Thanks in advance. Also, I installed a new roller, which I assume is suppose to roll. While the cable does travel around it and I can shift into all gears, the roller is now stationary....I can't really explain that one....any advice on that one would be appreciated as well. EDIT/UPDATE: I just looked at my old roller and removed the center piece from it. I have a feeling that the roller I just installed didn't have this metal cylinder in it...so that solves the roller problem.(see 3rd pic) ![]() ![]() |
| second wind |
Oct 12 2020, 07:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California
How funny is this......... I just washed my hands from the same job. Went to clean my lugs nuts with my new bench grinder wire wheel....took a look at the clutch roller wheel...it was wired in...went to 914 Rubber and bought the whole kit and kaboudle.....new roller was tight so I sanded it down a bit and rolls perfect. Terrycable looks to be extremely stout compared to others...like it....wish I could find a 7mm x 1.0 coupler nut/extension nut for adjustment screws but none to be found. Will buy some bicycle wrenches 11mm and grind them thin for ease of adjustment. Nice new cable with grease and proper cable holder part instead of wire....loving it!!
gg |
Craigers17 At the Risk of Becoming "That Guy"...I have another question Oct 12 2020, 04:59 PM
IronHillRestorations That all looks pretty good. You are correct in th... Oct 12 2020, 05:34 PM
wndsrfr You've got it right....no nut on the "rol... Oct 12 2020, 05:35 PM
maf914 Per the Porsche 914 PET diagram the bushing or sle... Oct 12 2020, 05:42 PM
Craigers17 Thanks for the replies and the information. I wil... Oct 12 2020, 05:55 PM
Jett
Thanks for the replies and the information. I wi... Oct 12 2020, 06:30 PM
Tdskip @Craigers17 - no risk of being "that guy... Oct 12 2020, 07:34 PM
Robson51 I bought this just to do clutch adjustment-
https... Oct 13 2020, 01:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th November 2026 - 03:54 AM |
