Plastic back pad |
Plastic back pad |
partwerks |
Jan 23 2021, 10:50 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Anyone used this?
Do you just slap the vinyl on the plastic, and end of story, or is there more to it than that? If it has bulges like the foam, I'm not getting why it says to reuse the foam?? https://914rubber.com/thermal-formed-3-piece-back-pad-core-1 https://914rubber.com/3-piece-back-pad-leatherette-set |
Mikey914 |
Jan 23 2021, 10:54 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These replace the cardboard. You need to harvest your foam pieces. We just completed the metal attachment prongs and will soon be included.
For attaching the flat vinyl next to the pad it is recommended that you staple a strip of cardboard to anchor it just like factory did. We will begin to off these premade just like factory did but they are offering at $1200+ Mark |
partwerks |
Jan 23 2021, 11:10 PM
These replace the cardboard. You need to harvest your foam pieces. We just completed the metal attachment prongs and will soon be included. For attaching the flat vinyl next to the pad it is recommended that you staple a strip of cardboard to anchor it just like factory did. We will begin to off these premade just like factory did but they are offering at $1200+ Mark Not seeing them in person, it appears they are shaped like the foam pieces/cardboard? |
bbrock |
Jan 24 2021, 02:37 PM
Not seeing them in person, it appears they are shaped like the foam pieces/cardboard? What you are seeing is the plastic board molded to fit the contours of the firewall it attaches to and to form pockets for the seat belt reels to fit behind the board. Not the same as the foam contour. This might help understand the process: http://www.914world.com/bbs2/index.php?s=&...t&p=2580773 |
Lo-Fi Version | Time is now: 8th June 2024 - 01:45 AM |
