| stickyfingers |
Mar 12 2021, 10:12 AM
Member ![]() ![]() Group: Members Posts: 168 Joined: 19-February 21 From: Toronto Member No.: 25,223 Region Association: Canada |
Hi everyone.
So thanks for everyone with their feedback on whether a PCCM or a Retro radio with BT would be the way to go in my 914. Clearly the PCCM is way too expensive and being in Canada getting one of those Retro Radios that maintain the period look are still very expensive. So I recall someone saying they installed a small BT amp which is the direction I went towards. I am able to use my radio and pipe music through Bluetooth to my car speakers (OEM). I will never use the radio because there is a lot of static on any FM channels so I wanted to get music playing from my phone. Hope this helps others that maybe looking to do something similar. I purchased these 2 items: https://www.amazon.ca/gp/product/B074FR4B7H...=UTF8&psc=1 and https://www.amazon.ca/gp/product/B071YH69GJ...=UTF8&psc=1 which powers the amp. Mounted the amp behind the radio with double sided tape and voila - beautiful sound from my phone. For $35CDN it's very cost effective. |
| pt_700 |
Mar 12 2021, 01:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,112 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California
could you elaborate a bit for the clueless (like me)?
i gather there are connections for the speakers on the amp. to get started, do you power it up and somehow link your phone and the amp via bluetooth? have a pic of the installation? |
| stickyfingers |
Mar 13 2021, 01:12 PM
could you elaborate a bit for the clueless (like me)? i gather there are connections for the speakers on the amp. to get started, do you power it up and somehow link your phone and the amp via bluetooth? have a pic of the installation? It was actually very simple. The amp ($25 CDN) has 2 screw downs pins for power which I took using the cigarette lighter adapter ($10 CDN on Amazon as per my links). I cut the + and - wire from the lighter adapter so I could screw in the wires to power the amp. The amp can be powered using 6v upto 47v so thankfully it can handle low and high voltages in case. The amp is left and right speaker screw downs. I spliced the left and the right speaker wires into the amp. Voila. Then use your bluetooth settings and connect to the amp when the key is on. Beautiful sounds from your speakers. See image below for a better look at it: It also has auxiliary 3.5mm input as well if you want to hook an ipod or another phone rather than bluetooth. This is intelligent enough to decide between BT and 3.5mm inputs. And the connection is immediate. You can also pause and skip songs and change the volume from the board. I just use my phone and hide the amp. I was thinking about hooking up buttons and wiring them but it's not necessary because I wanted to maintain the original look of the interior and not start drilling holes for buttons. Caveat: I left my stereo in there but I never use it so I actually just remove the speaker wires from it but left them there for easy connection if I ever need to sell the car the new owner wants the radio to play sound through the speakers. The radio powers up. I just don't see a need to connect it. But you could build a Y connected for the speaker wires to go to both the amp and the radio. I've stuck the amp (it's very small) with 2 sided tape so it's a little challenging to remove and put back but if you really want me to do it I will. lmk otherwise the instructions above are very straight forward. For the adventurous they can take the power from the radio or another source to power the amp. I just found that I wanted to control the source of the power in case of troubleshooting and the cigarette lighter adapter was a great option for me. Thanks and lmk if you need further info. For $35 it's a great option. |
stickyfingers Bluetooth while maintaining the look Mar 12 2021, 10:12 AM
76-914 I like it. Smart, small and inexpensive! :beer... Mar 12 2021, 12:19 PM
Tom_T
Hi everyone.
So thanks for everyone with their f... Mar 12 2021, 01:41 PM
913B That is cool.
Is there a device to switch between... Mar 13 2021, 05:43 PM
stickyfingers
That is cool.
Is there a device to switch betwee... Mar 13 2021, 05:46 PM
913B
That is cool.
Is there a device to switch betwe... Mar 13 2021, 05:57 PM
stickyfingers I have to figure out the speaker wires coming from... Mar 13 2021, 06:40 PM
Mitox
I have to figure out the speaker wires coming fro... Mar 14 2021, 08:12 AM
moldygreg
Hi everyone.
So thanks for everyone with their f... Mar 13 2021, 07:36 PM
stickyfingers No worries. It shouldn’t take you more than 30 m... Mar 13 2021, 07:43 PM
DC_neun_vierzehn
No worries. It shouldn’t take you more than 30 ... Mar 13 2021, 10:08 PM
stickyfingers
No worries. It shouldn’t take you more than 30... Mar 13 2021, 10:17 PM
pt_700 thanks for elaborating, now i get it! Mar 14 2021, 01:37 AM
stickyfingers Definitely. Switch will be necessary. You can also... Mar 14 2021, 09:01 AM
914e Somehow handsfree works through this? Mar 14 2021, 10:07 AM
stickyfingers
It does n... Mar 14 2021, 10:10 AM
Jett Cool solution!
We wanted to use BT but also t... Mar 14 2021, 10:47 AM
stickyfingers
Cool solution!
We wanted to use BT but also ... Mar 14 2021, 10:48 AM
Jett
[quote name='Jett' post='2899277' date='Mar 14 20... Mar 25 2021, 01:56 PM
Montreal914
Cool solution!
We wanted to use BT but also ... Mar 14 2021, 01:05 PM
moldygreg
[quote name='Jett' post='2899277' date='Mar 14 20... Mar 15 2021, 11:46 AM
stickyfingers
[quote name='Montreal914' post='2899317' date='Ma... Mar 15 2021, 12:20 PM
moldygreg
[quote name='Montreal914' post='2899317' date='M... Mar 15 2021, 01:18 PM
Jett
[quote name='Jett' post='2899277' date='Mar 14 20... Mar 15 2021, 09:27 PM
stickyfingers Glad to hear. It’s crazy how quickly it connects... Mar 15 2021, 01:23 PM
914forme To connect both radio and amp, you can place a zen... Mar 15 2021, 02:15 PM
Rotary'14 I got rid of stock radio, and mounted this on the... Mar 15 2021, 03:55 PM
stickyfingers
I got rid of stock radio, and mounted this on th... Mar 15 2021, 04:48 PM
bkrantz Not quite the same, but I am thinking about using ... Mar 15 2021, 08:35 PM
moldygreg
Not quite the same, but I am thinking about using... Mar 15 2021, 08:47 PM
stickyfingers To be honest you’d never look at the unit. I got... Mar 15 2021, 08:56 PM
Montreal914 @Jett
My question in post #21 got lost in all of ... Mar 15 2021, 09:08 PM
Rotary'14
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 25 2021, 01:59 PM
stickyfingers Just wanted to provide an update. I have moved on... Mar 25 2021, 11:22 AM
CoronaMike Here's MY bluetooth solution.
It's pl... Mar 25 2021, 01:10 PM
stickyfingers
It's p... Mar 25 2021, 01:13 PM
stickyfingers Is that needed only if there is noise on the line? Mar 25 2021, 02:08 PM
Rotary'14
Is that needed only if there is noise on the line... Mar 25 2021, 02:54 PM
stickyfingers
Is that needed only if there is noise on the lin... Mar 25 2021, 02:54 PM
wattele Hi I installed the same device.
Amazon order, inst... Apr 5 2021, 12:28 PM
stickyfingers
Amazon order, ins... Apr 5 2021, 12:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:56 PM |
