| stickyfingers |
Mar 12 2021, 10:12 AM
Member ![]() ![]() Group: Members Posts: 168 Joined: 19-February 21 From: Toronto Member No.: 25,223 Region Association: Canada |
Hi everyone.
So thanks for everyone with their feedback on whether a PCCM or a Retro radio with BT would be the way to go in my 914. Clearly the PCCM is way too expensive and being in Canada getting one of those Retro Radios that maintain the period look are still very expensive. So I recall someone saying they installed a small BT amp which is the direction I went towards. I am able to use my radio and pipe music through Bluetooth to my car speakers (OEM). I will never use the radio because there is a lot of static on any FM channels so I wanted to get music playing from my phone. Hope this helps others that maybe looking to do something similar. I purchased these 2 items: https://www.amazon.ca/gp/product/B074FR4B7H...=UTF8&psc=1 and https://www.amazon.ca/gp/product/B071YH69GJ...=UTF8&psc=1 which powers the amp. Mounted the amp behind the radio with double sided tape and voila - beautiful sound from my phone. For $35CDN it's very cost effective. |
| 913B |
Mar 13 2021, 05:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
That is cool.
Is there a device to switch between the Bluetooth input or the input of my regular radio to the speakers It would be nice to have normal radio or say push a button and have it go to BT. Any audio experts know if I can just rig a relay(s) and have it switch that way or would that cause problems. (IMG:style_emoticons/default/biggrin.gif) |
| stickyfingers |
Mar 13 2021, 05:46 PM
That is cool. Is there a device to switch between the Bluetooth output or the output of regular radio. It would be nice to have normal radio or say push a button and have it go to BT. Any audio experts know if I can just rig a relay(s) and have it switch that way or would that cause problems. (IMG:style_emoticons/default/biggrin.gif) I'm going to spend some time on this tomorrow and see if I can wire it so both can work simultaneously. I had it going on 1 side but for whatever reason it would mess up when hooking up the other speaker. I gave up but I'll get it going and provide some feedback. I had it going where both BT and radio were on at the same time. The reason I removed the speakers from the radio path was because my radio was getting a lot of static. This way I can just get a radio app to play the radio. But to each their own. |
| 913B |
Mar 13 2021, 05:57 PM
That is cool. Is there a device to switch between the Bluetooth output or the output of regular radio. It would be nice to have normal radio or say push a button and have it go to BT. Any audio experts know if I can just rig a relay(s) and have it switch that way or would that cause problems. (IMG:style_emoticons/default/biggrin.gif) I'm going to spend some time on this tomorrow and see if I can wire it so both can work simultaneously. I had it going on 1 side but for whatever reason it would mess up when hooking up the other speaker. I gave up but I'll get it going and provide some feedback. I had it going where both BT and radio were on at the same time. The reason I removed the speakers from the radio path was because my radio was getting a lot of static. This way I can just get a radio app to play the radio. But to each their own. Oh yeah huh why not just leave the BT and radio connected to the speakers. I don't plan on using both at the same time or have a switch to power on/off the BT module to turn it off and eliminate it completely. Thanks for your idea! |
| stickyfingers |
Mar 13 2021, 06:40 PM
I have to figure out the speaker wires coming from the radio. The minute I connect the radio leads to the speakers while connected to the amp it kills audio coming from the amp (BT audio stops - clicks).
Have to sort that out still. |
stickyfingers Bluetooth while maintaining the look Mar 12 2021, 10:12 AM
76-914 I like it. Smart, small and inexpensive! :beer... Mar 12 2021, 12:19 PM
pt_700 could you elaborate a bit for the clueless (like m... Mar 12 2021, 01:18 PM
stickyfingers
could you elaborate a bit for the clueless (like ... Mar 13 2021, 01:12 PM
Tom_T
Hi everyone.
So thanks for everyone with their f... Mar 12 2021, 01:41 PM
Mitox
I have to figure out the speaker wires coming fro... Mar 14 2021, 08:12 AM
moldygreg
Hi everyone.
So thanks for everyone with their f... Mar 13 2021, 07:36 PM
stickyfingers No worries. It shouldn’t take you more than 30 m... Mar 13 2021, 07:43 PM
DC_neun_vierzehn
No worries. It shouldn’t take you more than 30 ... Mar 13 2021, 10:08 PM
stickyfingers
No worries. It shouldn’t take you more than 30... Mar 13 2021, 10:17 PM
pt_700 thanks for elaborating, now i get it! Mar 14 2021, 01:37 AM
stickyfingers Definitely. Switch will be necessary. You can also... Mar 14 2021, 09:01 AM
914e Somehow handsfree works through this? Mar 14 2021, 10:07 AM
stickyfingers
It does n... Mar 14 2021, 10:10 AM
Jett Cool solution!
We wanted to use BT but also t... Mar 14 2021, 10:47 AM
stickyfingers
Cool solution!
We wanted to use BT but also ... Mar 14 2021, 10:48 AM
Jett
[quote name='Jett' post='2899277' date='Mar 14 20... Mar 25 2021, 01:56 PM
Montreal914
Cool solution!
We wanted to use BT but also ... Mar 14 2021, 01:05 PM
moldygreg
[quote name='Jett' post='2899277' date='Mar 14 20... Mar 15 2021, 11:46 AM
stickyfingers
[quote name='Montreal914' post='2899317' date='Ma... Mar 15 2021, 12:20 PM
moldygreg
[quote name='Montreal914' post='2899317' date='M... Mar 15 2021, 01:18 PM
Jett
[quote name='Jett' post='2899277' date='Mar 14 20... Mar 15 2021, 09:27 PM
stickyfingers Glad to hear. It’s crazy how quickly it connects... Mar 15 2021, 01:23 PM
914forme To connect both radio and amp, you can place a zen... Mar 15 2021, 02:15 PM
Rotary'14 I got rid of stock radio, and mounted this on the... Mar 15 2021, 03:55 PM
stickyfingers
I got rid of stock radio, and mounted this on th... Mar 15 2021, 04:48 PM
bkrantz Not quite the same, but I am thinking about using ... Mar 15 2021, 08:35 PM
moldygreg
Not quite the same, but I am thinking about using... Mar 15 2021, 08:47 PM
stickyfingers To be honest you’d never look at the unit. I got... Mar 15 2021, 08:56 PM
Montreal914 @Jett
My question in post #21 got lost in all of ... Mar 15 2021, 09:08 PM
Rotary'14
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 25 2021, 01:59 PM
stickyfingers Just wanted to provide an update. I have moved on... Mar 25 2021, 11:22 AM
CoronaMike Here's MY bluetooth solution.
It's pl... Mar 25 2021, 01:10 PM
stickyfingers
It's p... Mar 25 2021, 01:13 PM
stickyfingers Is that needed only if there is noise on the line? Mar 25 2021, 02:08 PM
Rotary'14
Is that needed only if there is noise on the line... Mar 25 2021, 02:54 PM
stickyfingers
Is that needed only if there is noise on the lin... Mar 25 2021, 02:54 PM
wattele Hi I installed the same device.
Amazon order, inst... Apr 5 2021, 12:28 PM
stickyfingers
Amazon order, ins... Apr 5 2021, 12:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:52 PM |
