> Bluetooth while maintaining the look
stickyfingers
post Mar 12 2021, 10:12 AM
Hi everyone.
So thanks for everyone with their feedback on whether a PCCM or a Retro radio with BT would be the way to go in my 914. Clearly the PCCM is way too expensive and being in Canada getting one of those Retro Radios that maintain the period look are still very expensive.
So I recall someone saying they installed a small BT amp which is the direction I went towards. I am able to use my radio and pipe music through Bluetooth to my car speakers (OEM). I will never use the radio because there is a lot of static on any FM channels so I wanted to get music playing from my phone. Hope this helps others that maybe looking to do something similar.
I purchased these 2 items:
https://www.amazon.ca/gp/product/B074FR4B7H...=UTF8&psc=1
and
https://www.amazon.ca/gp/product/B071YH69GJ...=UTF8&psc=1
which powers the amp. Mounted the amp behind the radio with double sided tape and voila - beautiful sound from my phone.
For $35CDN it's very cost effective.
914forme
post Mar 15 2021, 02:15 PM
To connect both radio and amp, you can place a zener diode on each circuit this will block the back feed of power through the circuits, and keep the magic smoke in the components.
Just takes 4 of them one on each 12V Positive leg, I guess I could diagram it out, but it is not hard just need to remember which way the stripe goes. It should work. Or you can use a switch and a relay, to pick the source you want. It will require 2 relays.
Im going to try one of these in my Boxster build
stickyfingers   Bluetooth while maintaining the look   Mar 12 2021, 10:12 AM
76-914   I like it. Smart, small and inexpensive! :beer...   Mar 12 2021, 12:19 PM
pt_700   could you elaborate a bit for the clueless (like m...   Mar 12 2021, 01:18 PM
stickyfingers   could you elaborate a bit for the clueless (like ...   Mar 13 2021, 01:12 PM
Tom_T   Hi everyone. So thanks for everyone with their f...   Mar 12 2021, 01:41 PM
913B   That is cool. Is there a device to switch between...   Mar 13 2021, 05:43 PM
stickyfingers   That is cool. Is there a device to switch betwee...   Mar 13 2021, 05:46 PM
913B   That is cool. Is there a device to switch betwe...   Mar 13 2021, 05:57 PM
stickyfingers   I have to figure out the speaker wires coming from...   Mar 13 2021, 06:40 PM
Mitox   I have to figure out the speaker wires coming fro...   Mar 14 2021, 08:12 AM
moldygreg   Hi everyone. So thanks for everyone with their f...   Mar 13 2021, 07:36 PM
stickyfingers   No worries. It shouldn’t take you more than 30 m...   Mar 13 2021, 07:43 PM
DC_neun_vierzehn   No worries. It shouldn’t take you more than 30 ...   Mar 13 2021, 10:08 PM
stickyfingers   No worries. It shouldn’t take you more than 30...   Mar 13 2021, 10:17 PM
pt_700   thanks for elaborating, now i get it!   Mar 14 2021, 01:37 AM
stickyfingers   Definitely. Switch will be necessary. You can also...   Mar 14 2021, 09:01 AM
914e   Somehow handsfree works through this?   Mar 14 2021, 10:07 AM
stickyfingers   Somehow handsfree works through this? It does n...   Mar 14 2021, 10:10 AM
Jett   Cool solution! We wanted to use BT but also t...   Mar 14 2021, 10:47 AM
stickyfingers   Cool solution! We wanted to use BT but also ...   Mar 14 2021, 10:48 AM
Jett   [quote name='Jett' post='2899277' date='Mar 14 20...   Mar 25 2021, 01:56 PM
Montreal914   Cool solution! We wanted to use BT but also ...   Mar 14 2021, 01:05 PM
moldygreg   [quote name='Jett' post='2899277' date='Mar 14 20...   Mar 15 2021, 11:46 AM
stickyfingers   [quote name='Montreal914' post='2899317' date='Ma...   Mar 15 2021, 12:20 PM
moldygreg   [quote name='Montreal914' post='2899317' date='M...   Mar 15 2021, 01:18 PM
Jett   [quote name='Jett' post='2899277' date='Mar 14 20...   Mar 15 2021, 09:27 PM
stickyfingers   Glad to hear. It’s crazy how quickly it connects...   Mar 15 2021, 01:23 PM
914forme   To connect both radio and amp, you can place a zen...   Mar 15 2021, 02:15 PM
Rotary'14   I got rid of stock radio, and mounted this on the...   Mar 15 2021, 03:55 PM
stickyfingers   I got rid of stock radio, and mounted this on th...   Mar 15 2021, 04:48 PM
bkrantz   Not quite the same, but I am thinking about using ...   Mar 15 2021, 08:35 PM
moldygreg   Not quite the same, but I am thinking about using...   Mar 15 2021, 08:47 PM
stickyfingers   To be honest you’d never look at the unit. I got...   Mar 15 2021, 08:56 PM
Montreal914   @Jett My question in post #21 got lost in all of ...   Mar 15 2021, 09:08 PM
Rotary'14   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 25 2021, 01:59 PM
stickyfingers   Just wanted to provide an update. I have moved on...   Mar 25 2021, 11:22 AM
CoronaMike   Here's MY bluetooth solution. It's pl...   Mar 25 2021, 01:10 PM
stickyfingers   Here's MY bluetooth solution. It's p...   Mar 25 2021, 01:13 PM
stickyfingers   Is that needed only if there is noise on the line?   Mar 25 2021, 02:08 PM
Rotary'14   Is that needed only if there is noise on the line...   Mar 25 2021, 02:54 PM
stickyfingers   Is that needed only if there is noise on the lin...   Mar 25 2021, 02:54 PM
wattele   Hi I installed the same device. Amazon order, inst...   Apr 5 2021, 12:28 PM
stickyfingers   Hi I installed the same device. Amazon order, ins...   Apr 5 2021, 12:35 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:54 PM
