944 CV joints on 914 axle, A couple of questions |
john77 |
May 13 2021, 05:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I'm building a new set of these for my car. The old set on my car right now never had the 4mm machined off - it had one CV joint welded on and the other floating - so after reading through SirAndy's thread in the classics section I have a couple of questions.
[url](IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1620947054.1.jpg)[/url] Do I use the washer that sits between the axle and the CV joint? (I'm guessing that's what it's for on the 944 axle... ) Is there a correct orientation for the CV joint - i.e. the line on the CV should be on the outside or inside - or doesn't it matter? And what's the best finish for axles, powdercoating? Any durable homebrew alternatives I can do myself? John |
76-914 |
May 13 2021, 07:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Yes. Notice that it is cupped. Concaved side towards CV. Tell me more about machining 4mm off or direct me to where I can read up on it. (IMG:style_emoticons/default/beerchug.gif)
john77 |
May 13 2021, 11:41 PM
Looks like I was originally reading an older thread, but you asking made me accidentally find the full write up, and it turns out you don’t need the washer and the line needs to be on the outside… so now I know (IMG:style_emoticons/default/biggrin.gif) .
Here you go: http://www.914world.com/bbs2/index.php?showtopic=80641 Yes. Notice that it is cupped. Concaved side towards CV. Tell me more about machining 4mm off or direct me to where I can read up on it. (IMG:style_emoticons/default/beerchug.gif) |
76-914 |
May 14 2021, 09:19 AM
Looks like I was originally reading an older thread, but you asking made me accidentally find the full write up, and it turns out you don’t need the washer and the line needs to be on the outside… so now I know (IMG:style_emoticons/default/biggrin.gif) . Here you go: http://www.914world.com/bbs2/index.php?showtopic=80641 Yes. Notice that it is cupped. Concaved side towards CV. Tell me more about machining 4mm off or direct me to where I can read up on it. (IMG:style_emoticons/default/beerchug.gif) Right you are. I missed the 944 and read only 914. My bad. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 05:28 PM |
