LCOX |
Member ![]() ![]() Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None ![]() |
Having a problem with the headlights on my 914. Both headlights work and they both open and retract but they don't raise up all the way. They only open up about 75%. Both beams are shining on the ground when fully open. I've posted a picture. I very made every adjustment known to man but still they aren't raised fully. Any advice. L
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
I think you are off by a tooth or two at the motor.
Take the relay out with the headlights up so they stay up with the key off (and so you won't loose a finger if the lights close for some reason - those motors are strong). Take the arm off the motor and see if you can clock it so you get the full range of motion. One tooth will move the arm a good bit. Zach |
Lo-Fi Version | Time is now: 12th July 2025 - 11:05 AM |
