Rear trunk lock, HELP! |
Morph914 |
Nov 20 2021, 02:16 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
As I near the end of my restoration, I was just refitting the rear trunk lid back on the car. The fit seemed to be good, and as I brought it down it latched. When I tried to open it nothing happened. I figured it was in the locked position, but after turning the lock to the opposite position, it still would not open. I must have reversed the plunger or opening pin when I had it apart to clean. (IMG:style_emoticons/default/headbang.gif)
Any ideas on how to get it opened would be appreciated. Before I get the Dremel or drill out to do surgery, I’m hoping someone has a less invasive solution. Thanks in advance, John |
Shivers |
Nov 20 2021, 02:51 PM
Senior Member Group: Members Posts: 2,411 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hi. I went out and looked. I can only see one way that no metal gets bent, that I would try. From the engine compartment, pop out the cup the front top latch goes into in the trunk. Get every ratchet extension you own and, one at a time send in a 10mm socket and as many extensions as it takes to un-bolt the tail light. I was able to put my arm through the tail light opening in the body and reach the two bolts that hold in the locking mechanism. Worth a try.
Lo-Fi Version | Time is now: 3rd June 2024 - 03:31 AM |
