Rear trunk lock, HELP! |
Morph914 |
Nov 20 2021, 02:16 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
As I near the end of my restoration, I was just refitting the rear trunk lid back on the car. The fit seemed to be good, and as I brought it down it latched. When I tried to open it nothing happened. I figured it was in the locked position, but after turning the lock to the opposite position, it still would not open. I must have reversed the plunger or opening pin when I had it apart to clean. (IMG:style_emoticons/default/headbang.gif)
Any ideas on how to get it opened would be appreciated. Before I get the Dremel or drill out to do surgery, I’m hoping someone has a less invasive solution. Thanks in advance, John |
SirAndy |
Nov 20 2021, 05:11 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Do a search here, the easiest way to do this is:
- Push both of the plastic cups that hold the targa top latches from the engine compartment side into the rear trunk - Have a helper shine a flashlight through one of the holes and onto the back of the latch - Get several long extensions for your ratchet wrench and put a 10mm nut on the end - Slowly fiddle the extensions through the other hole until you can reach the back of the lock - Remove the two to 10mm bolts - Open trunk (IMG:style_emoticons/default/smash.gif) PS: This might work better if you put a swivel at the end |
bdstone914 |
Nov 20 2021, 07:50 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Do a search here, the easiest way to do this is: - Push both of the plastic cups that hold the targa top latches from the engine compartment side into the rear trunk - Have a helper shine a flashlight through one of the holes and onto the back of the latch - Get several long extensions for your ratchet wrench and put a 10mm nut on the end - Slowly fiddle the extensions through the other hole until you can reach the back of the lock - Remove the two to 10mm bolts - Open trunk (IMG:style_emoticons/default/smash.gif) PS: This might work better if you put a swivel at the end @Morph914 Another member said go in thru the plastic cup holes and use a 2 iron to reach behind the latch and trip in catch. |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:09 AM |
