track suspension info needed... |
Jeroen |
Jan 7 2005, 10:28 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Hey all,
Gathering suspension parts for my track car and I'm trying to make up my mind I'd like to go with yellow adj. Koni's. Does anybody now up to what spring rate the yellow Koni's can handle? Should I go for torsion bars (22 or 23mm) I can have the struts modified for coilovers for about the same money I'd need to spend on the t-bars Coil over springs are pretty cheap and I wouldn't be stuck with just one spring rate Any info on springrates in relation to the weight of the car? I'm aiming for about 1750# for the car and was thinking about starting with 275 or 300# rear springs Does anybody know the spring rates for the front torsion bars? I've been looking into it, but different sources quote (very) different rates (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Anybody running big front t-bars (22 or 23mm), what springs are you using in the rear? I know, lots of questions, but I'm trying to figure out my options, so any advise is welcome Right now I'm looking at too many unknowns to make a decent guestimate thanks... Jeroen |
john rogers |
Jan 7 2005, 02:20 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Your question should get lots of replys??? I use 23mm front t-bars and 300# rear springs and have adjustable Koni shocks on all four corners. I also use a front and rear sway bar with a GT limited slip. This has worked well since the car runs on Goodyear slicks and is great on tracks that are smooth but it is hell on a rough surface such as we raced on in Tacate Mx last year. Our rule of thumb was to go just stiff enough on the rear to keep the inside front wheel planted in very tight corners and so far has worked well.
Lo-Fi Version | Time is now: 2nd June 2024 - 09:10 AM |
