track suspension info needed... |
Jeroen |
Jan 7 2005, 10:28 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Hey all,
Gathering suspension parts for my track car and I'm trying to make up my mind I'd like to go with yellow adj. Koni's. Does anybody now up to what spring rate the yellow Koni's can handle? Should I go for torsion bars (22 or 23mm) I can have the struts modified for coilovers for about the same money I'd need to spend on the t-bars Coil over springs are pretty cheap and I wouldn't be stuck with just one spring rate Any info on springrates in relation to the weight of the car? I'm aiming for about 1750# for the car and was thinking about starting with 275 or 300# rear springs Does anybody know the spring rates for the front torsion bars? I've been looking into it, but different sources quote (very) different rates (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Anybody running big front t-bars (22 or 23mm), what springs are you using in the rear? I know, lots of questions, but I'm trying to figure out my options, so any advise is welcome Right now I'm looking at too many unknowns to make a decent guestimate thanks... Jeroen |
drew365 |
Jan 7 2005, 02:55 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
Jeroen; My setup is:
Front - 22mm hollow torsion bars, adjustable Koni shocks, 23mm Smart Racing sway bar. Rear - 400# Eibach springs on adjustable perches, Bilstein shocks, 16mm Weltmeister sway bar. My car weighs about 2000#. It is very stiff and neutral with little to no body roll. My front bar is usually about the mid point and my rear bar is near full soft. I make small adjustments for different tracks but usually no more than 1/2" on either sway bar. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:51 PM |
