| GregAmy |
Jan 6 2022, 06:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Went to move the 914 for winter storage today and the outer door handle was INOP, acting as if the door was locked. I unlocked it with the key, no change; I went in from the passenger side to unlock it -- and it was already unlocked. Had to roll down the window so I could reach in from outside.
Behaves as expected from the inside door handle, locked and unlocked. Haven't looked at it, have not pulled the door card. Just curious if this is a known problem so I can consider buying any required parts in advance. Thanks! |
| Mikey914 |
Jan 6 2022, 07:41 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Yep, just clean up and lubricate. It takes longer to get it out than to change out the “cam”
GregAmy Outer Door Handle INOP Jan 6 2022, 06:12 PM
lesorubcheek
Went to move the 914 for winter storage today and... Jan 6 2022, 06:21 PM
GregAmy Looks easy enough, I'll replace both. Thanks... Jan 6 2022, 06:52 PM
Jett It is important to note that the reason these brea... Jan 6 2022, 07:14 PM
TheCabinetmaker Jett is referring to the latch, not the lock. They... Jan 7 2022, 08:13 AM
dr914@autoatlanta.com yes the plastic door cam has broken. It was the v... Jan 7 2022, 09:23 AM
GregAmy Follow up: yup, finally got around to getting in t... Mar 1 2022, 05:15 PM
dr914@autoatlanta.com door latch cam, very first aftermarket part we eve... Mar 1 2022, 05:29 PM
Mikey914 Neither have we :D Mar 1 2022, 05:44 PM
GregAmy ...and the door handle? Plastic part don't wor... Mar 1 2022, 06:50 PM
Mikey914 They should have flex, but you are correct, if the... Mar 2 2022, 02:40 AM
GregAmy I'll concur that they are/were a mess. Yes, th... Mar 2 2022, 06:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:37 PM |
