| Eric_Shea |
Dec 27 2021, 04:59 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
PMB Performance DirectFit™ DOT Stainless Brake Line Specifications Built to the Following Standards • DOT - FMVSS 106 • SAE - J1401 • ISO - 3996 • GB - 16897-2010 Composition • PTFE (Teflon®) inner lining • Braided 304 Stainless Steel Covering • Clear UV Protective PVC Outer Cover • Steel fittings: Triple Zinc and Nickel finishes Features • High-performance ultra-low expansion rate of 0.000295cc/ft. at 4,000 psi (ZeroFlex™) • ZeroFlex™ offers extremely precise pedal modulation and feel • DirectFit™ OE designed fittings and vehicle specific lengths accommodate ease of installation • Tough UV protective PVC outer coating to protect the braid and resist impact and abrasions • Protective fitting caps reduce fatigue • Tested to exceed DOT standards • All lines pressure tested to 4250 psi • Ultra-high burst pressure rated to 12,550-13,500 psi • Extreme temperature resistance -70℃/-94°F to +260℃/500°F • Compatibility: for all non-petroleum brake fluids DOT3, DOT4, DOT4 LV, DOT5.1 Lifetime Warranty on all Stainless Steel Line Sets Group Buy Pricing: $99.00 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th*** ![]() PMB Performance DirectFit™ DOT Rubber Brake Line Specifications Built to the Following Standards • DOT - FMVSS 106 • SAE - J1401 • ISO - 3996 • GB - 16897-2010 Unique 5-Layer Composition • EPDM Inner Layer (excellent resistance to non-petroleum-based fluids)) • Polyester (OET) Inner Braid • EPDM Middle Interleaf (prevents abrasion) • PVA Outer Braid (provides strong bonding between layers) • EPDM Outer Layer for Excellent Ozone and UV Resistance Features • High-performance low expansion rate of 0.14cc/ft. at 1,500 psi (LowFlex™) • LowFlex™ offers extremely precise pedal modulation and feel over other rubber lines • DirectFit™ OE designed fittings and vehicle specific lengths accommodate ease of installation • Tough UV and Ozone protective EPDM outer coating • Tested to exceed DOT standards • Unique 5-Layer Composition • 10-Year Warranty • Extreme temperature resistance -50℃/-122°F to +121℃/250°F • Compatibility: for all non-petroleum brake fluids DOT3, DOT4, DOT4 LV, DOT5.1 10-Year Warranty on all Rubber Line Sets Group Buy Pricing: $39.95 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th*** ![]() |
| Literati914 |
Jan 11 2022, 01:43 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,392 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
If I can still get in on this ... Id take two sets of rubber lines for later struts. thx.
Eric_Shea Group Buy: Announcing PMB DirectFit Brake Lines Dec 27 2021, 04:59 PM
NARP74 I'm in for a set of SS Dec 27 2021, 05:39 PM
mepstein I’ll take a set of rubber lines. Dec 27 2021, 05:58 PM
iankarr Beautiful work. Congrats, @Eric_Shea ! Thank... Dec 27 2021, 06:04 PM
bossboy302 In for set of rubber lines-thx. Dec 27 2021, 06:16 PM
treemn One set of each style please.
Thanks Eric! Dec 27 2021, 07:38 PM
GermermanCarGuy I'm in for a set of rubber lines.
Thanks in ad... Dec 27 2021, 08:27 PM
BillJ Eric- i have my calipers on the way to you right n... Dec 27 2021, 09:09 PM
Eric_Shea
Eric- i have my calipers on the way to you right ... Dec 28 2021, 01:57 PM
Van B Could you make some (stainless) for my 996 too?... Dec 27 2021, 09:18 PM
Eric_Shea
Could you make some (stainless) for my 996 too?... Dec 28 2021, 01:58 PM
Van B
Could you make some (stainless) for my 996 too?... Dec 28 2021, 05:57 PM
Lg914 In for a set of stainless. Dec 27 2021, 09:24 PM
Movin6 I'll take a set of SS for a 914-6!
Please ... Dec 27 2021, 09:35 PM
SKL1 Eric- one set SS for 914-6 front and rear caliper... Dec 27 2021, 09:53 PM
ndfrigi @Eric_Shea 1 set of rubber lines for 74 pls. than... Dec 27 2021, 10:07 PM
jim_hoyland Do the front 911M calipers take the same hose as t... Dec 27 2021, 10:34 PM
Eric_Shea
Do the front 911M calipers take the same hose as ... Dec 28 2021, 02:00 PM
djway 2 rubber pls Dec 27 2021, 10:52 PM
dlee6204 I'll take a rubber set. Dec 28 2021, 03:42 AM
Luke M I'm in for a set of the late 914 SS lines but ... Dec 28 2021, 08:15 AM
Eric_Shea
I'm in for a set of the late 914 SS lines but... Dec 28 2021, 02:20 PM
Luke M
[quote name='Luke M' post='2970053' date='Dec 28 ... Dec 28 2021, 02:43 PM
Eric_Shea
[quote name='Luke M' post='2970053' date='Dec 28... Dec 28 2021, 02:50 PM
Luke M
[quote name='Luke M' post='2970128' date='Dec 28 ... Dec 28 2021, 04:08 PM
Eric_Shea
Your saying that the early 914 fronts will work w... Dec 28 2021, 05:03 PM
sixaddict I am in for one set of rubber lines.
Thanks Dec 28 2021, 08:52 AM
rhodyguy A set of rubber ones please. Are these to be order... Dec 28 2021, 08:56 AM
Eric_Shea
A set of rubber ones please. Are these to be orde... Dec 28 2021, 02:48 PM
branston I'll take a set of rubber.
How do we get paym... Dec 28 2021, 09:12 AM
DRPHIL914 Eric,
I am in for a set of SS lines for my ... Dec 28 2021, 10:45 AM
Mikey914 Nice Dec 28 2021, 11:04 AM
bobboinski I'll take one set of rubber, please. Dec 28 2021, 11:07 AM
Steve I will take two rubber sets Dec 28 2021, 11:46 AM
emerygt350 1 set of rubber please. Dec 28 2021, 12:11 PM
JamesM Sign me up for 3 stainless and 1 rubber! Dec 28 2021, 02:03 PM
TJB/914 :D
Eric,
I'll take a rubber set for my 1974 ... Dec 28 2021, 06:57 PM
DBF I would like a set of rubber lines. New to the fo... Dec 28 2021, 08:56 PM
roundtwo Looking good!
I'll take a set of the rubbe... Dec 28 2021, 09:02 PM
914e I can't decide on rubber or stainless so I wil... Dec 28 2021, 10:47 PM
DaveB I'll take a set of rubber lines.
DaveB Dec 28 2021, 11:21 PM
Rleog I have a ‘74 914/4 with stock rear and ‘88 Car... Dec 29 2021, 05:23 AM
Zimms One set of Stainless, please Dec 29 2021, 07:49 AM
TX914 I'll take one set of SS lines for a 76 please.... Dec 29 2021, 09:00 AM
akp2002 I would like a set of the 914 SS lines please. Dec 29 2021, 10:20 AM
mlmgm Eric,
Two SS sets for 914’s please
Thanks, M... Dec 29 2021, 10:49 AM
burlybryan Eric,
I would like a set of rubber lines for my ... Dec 29 2021, 11:23 AM
mb911 I would like a set of rubber ones Dec 29 2021, 11:29 AM
Jack Standz I'll take an early stainless set and an early ... Dec 29 2021, 11:53 AM
troth Better put a rubber set aside for the U-boat.
-To... Dec 29 2021, 12:03 PM
Hollybrook A set of SS please: 1973 914-4 1.7L. Dec 29 2021, 12:08 PM
fiacra I'll take a rubber set for my 1975 1.8. Thank... Dec 29 2021, 01:10 PM
markhoward Would like 2 SS sets. One is for a standard 78 91... Dec 29 2021, 01:51 PM
Mike Bellis I'm in if they fit my 930 calipers. Do they? Dec 29 2021, 03:42 PM
Eric_Shea
... Dec 29 2021, 06:01 PM
Mike Bellis How do I buy?
Early SS kit.
special link? Crank... Dec 29 2021, 06:15 PM
Eric_Shea
How do I buy?
Early SS kit.
special link? Cran... Dec 29 2021, 06:35 PM
pvollma I'd like a set of stainless steel for a 76. Th... Dec 30 2021, 07:26 PM
71six I would like a set of the rubber lines for a 1973 ... Dec 31 2021, 03:27 PM
Retired tech I’m in for a set of early rubber lines and washe... Jan 1 2022, 04:04 PM
PaulFV8 I’m in for a set SS, I will use 911 front struts... Jan 2 2022, 01:43 PM
jim_hoyland Order submitted for two sets of rubber hoses. Than... Jan 2 2022, 04:52 PM
jwinner
[b][size=4]PMB Performance DirectFit™ DOT St... Jan 3 2022, 06:33 PM
Eric_Shea :bump: wrapping it up this week gang. Thank you to... Jan 11 2022, 12:44 PM
Luke M
:bump: wrapping it up this week gang. Thank you t... Jan 12 2022, 05:54 PM
Eric_Shea
:bump: wrapping it up this week gang. Thank you ... Jan 15 2022, 11:47 AM
gandalf_025 I’m in for a set of stainless for a
70-6… Jan 12 2022, 09:38 AM
rfinegan I will take a set of SS line for my 75 914
-Thank... Jan 12 2022, 09:45 AM
Chris H. I'll take one set of rubber lines for a '7... Jan 12 2022, 10:37 AM
ndfrigi Thank you Eric! Got mine yesterday! Except... Jan 12 2022, 11:19 AM
beech4rd I'm in for a set of rubber lines for a '73... Jan 12 2022, 11:56 AM
rhodyguy I mailed payment today. The meter is running on th... Jan 12 2022, 12:27 PM
dstudeba 1 set of rubber lines for a 74 914 please Jan 12 2022, 12:28 PM
JRust Hey Eric do you have the Hard lines available as w... Jan 12 2022, 05:29 PM
Eric_Shea
Hey Eric do you have the Hard lines available as ... Jan 15 2022, 11:46 AM
Alain V. Oooops almost missed this.
I'll take a set of ... Jan 13 2022, 06:58 AM
johnswint3 I'm in for a rubber set for a 74. Jan 13 2022, 08:26 AM
Kansas 914 Hi Eric,
I am in for 1 set of rubber lines for th... Jan 13 2022, 09:19 AM
jesse7flying I'm in for a set of rubber lines for my '7... Jan 13 2022, 09:26 AM
relentless Eric, I'd like a set in rubber for my 76. Tha... Jan 13 2022, 04:12 PM
maf914 Eric, I would like one set of SS and one set of ru... Jan 13 2022, 04:17 PM
jc73-914 Hi Eric, I’d like to get a set of SS please.
Th... Jan 13 2022, 10:11 PM
808 WRX I would like one late rubber set.
Thank you!
... Jan 14 2022, 01:11 AM
seanpaulmc Hello Eric -
I will take a rubber set for a ... Jan 14 2022, 07:35 AM
vitamin914 Please have Holly PM me to order a set of SS lines... Jan 14 2022, 01:29 PM
915-1 One early rubber line set please...thanks! Jan 14 2022, 05:46 PM
Rob914 One set of early stainless please. Jan 14 2022, 06:43 PM
hex9145 i would like a set of the SS Jan 14 2022, 09:08 PM
oldfartwithaporsche Please put me down for a set of SS. Jan 14 2022, 10:02 PM
gcrotvik 4 sets of the PMB Performance DirectFit™ DOT Rub... Jan 14 2022, 10:23 PM
wes One set of SS please and thanks Eric. Jan 14 2022, 10:49 PM
dyw914 One set of rubber lines for a 73 please. Jan 15 2022, 10:29 AM
Unpretentious Eric,
I’d liked to get a late rubber set.
Than... Jan 15 2022, 11:07 AM
RAX914 I’ll take a rubber set for a ‘72 please Jan 15 2022, 11:10 AM
mb911 Ordered and paid. Thanks for offering these. Jan 15 2022, 11:19 AM
Puebloswatcop Eric, I'd like 1 set of SS lines for a '74... Jan 15 2022, 11:24 AM
Eric_Shea
Eric, I'd like 1 set of SS lines for a '7... Jan 15 2022, 11:40 AM
Eric_Shea ***Last Day for the Group Buy Pricing Gang***
Tha... Jan 15 2022, 11:42 AM
euro911 Eric ( @Eric_Shea ), sorry I'm late to the par... Jan 15 2022, 01:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th October 2026 - 11:54 AM |
