5 -lug conversion questions |
jmargush |
Jan 28 2022, 03:04 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I have a line on a 69 912 front and rear suspension.
Would this be a viable donor to set a 914 up for 5-lug? Are any of the rear parts applicable, i.e. hubs/axels, calipers? Would Cookie cutter rims fit this set up on a narrow body car? |
frostyf |
Jan 29 2022, 07:45 PM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Hi, I'm also trying to gather parts for a 5stud conversion and wanted to ask for some help ID'ing 911 strut types from their part numbers. I'm trying to find 911 boge struts with the later ball jt connection (wedge pin not pinch bolt) and 3" caliper spacing.
I've seen some numbered 901-341-079-01 and 901-341-080-02 and from the pet images I've found they seem 3" (M caliper compatible) but I can't work out what type of ball jt they take. Does anyone know or know where I should look to find out?? |
Mark Henry |
Jan 30 2022, 12:05 AM
Hi, I'm also trying to gather parts for a 5stud conversion and wanted to ask for some help ID'ing 911 strut types from their part numbers. I'm trying to find 911 boge struts with the later ball jt connection (wedge pin not pinch bolt) and 3" caliper spacing. I've seen some numbered 901-341-079-01 and 901-341-080-02 and from the pet images I've found they seem 3" (M caliper compatible) but I can't work out what type of ball jt they take. Does anyone know or know where I should look to find out?? To borrow Mark's "don’t quote me on that" I think all the 3" struts are pinch bolt. I have the 3" with the pinch bolt, they work okay, make sure the hole is round and just check the torque and condition often. There's a member that made new CNC wedge bolt ends for his 3" struts, that you cut off the old and weld on the new end. You could do the same thing by cutting off the wedge end from a donor set of /4 struts. I now have three 914's all with 3" struts, this is how I plan to repair them when the time comes. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:03 PM |
