Common plenum or individual runners???, for gas milage and drivability |
Mueller |
Dec 16 2004, 10:04 PM
for my 2316 it seems that the stock plenum might be reaching it's limits as far as volume goes.....so, I either fabricate a larger common plenum, or go with individual throttle bodies such as TWM or Jenvey*
single plenum would be easiest, but the individual throttle bodies look better (IMG:style_emoticons/default/smile.gif) has anyone switched from one to the other on the same motor with everything else being the same??? *Jake Raby is the U.S. distributor of these.... |
Mark Henry |
Jan 14 2005, 01:31 PM
I can't believe I didn't see this thread before... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Anyways...I'm also debating a IR or plenum system for my 2.7/4. A Honda Accord 2.0 FI TB....at 64mm it's huge compared to a 914 TB. Not too much crap on it, has an idle bleed screw, but it does rotate opposite from a 914 TB, so I'd have to get a new TPS. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Attached image(s) |
