JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,663 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
Since the world was down (stupid hackers (IMG:style_emoticons/default/mad.gif) ), I was not able to let you guys know that I had a promotion going on last month (unless you were on my mailing list).
To make up for that, I've created a special 914World discount - 15% off everything on the JWest Engineering website. (IMG:style_emoticons/default/santa_smiley.gif) Enter the coupon code "World22" or you can click this link to automatically apply the discount and start shopping: https://www.jwestengineering.com/?ApplyPromo=world22 Enjoy! James jwestengineering.com |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,954 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
I'd like to get the 914 Fog Light Module, but I just (finally) upgraded my headlights to LED. I now have that LED headlight/Fog Light issue that is well known. The fix is well known as well: disconnect the blue/white wire at fuse #1 and ground directly to chassis. All described here: http://www.914world.com/bbs2/index.php?showtopic=344457
So: Can I still install the JWest fog light mod? How does that change/impact the issue or solution? In other words, can I have LED headlights, the JWest fog light mod, and have everything work the way it's supposed to? I did some searching and couldn't find anything definitive. Thanks for any help. |
JWest |
I'd like to get the 914 Fog Light Module, but I just (finally) upgraded my headlights to LED. I now have that LED headlight/Fog Light issue that is well known. The fix is well known as well: disconnect the blue/white wire at fuse #1 and ground directly to chassis. All described here: http://www.914world.com/bbs2/index.php?showtopic=344457 So: Can I still install the JWest fog light mod? How does that change/impact the issue or solution? In other words, can I have LED headlights, the JWest fog light mod, and have everything work the way it's supposed to? I did some searching and couldn't find anything definitive. Thanks for any help. This is documented in the fog module instructions - once you have done the high beam feature defeat by grounding the white/blue wire, the fog module will work fine with LED headlights. James |
Lo-Fi Version | Time is now: 1st August 2025 - 08:43 AM |
