| bkrantz |
Dec 12 2022, 08:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,741 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I recently got a Quickjack 7000 TLX. I need the long X model to reach the jack points on my other vehicles. But I have failed to lift the 914.
My first attempt had the Quickjacks in the "official" positions, i.e. with the lower base pivots forward. Note this is not what I consider safe for 911s and probably for 914s, since the car center of gravity can end up outside (behind) the end of the lower base. Attached thumbnail(s) |
| 76-914 |
Dec 12 2022, 09:29 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,920 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Bob, It has been pointed out to me that those aren't necessarily jack pads but rather attach points used during assembly. Just as long as your under the long your OK. (IMG:style_emoticons/default/beerchug.gif)
| mepstein |
Dec 12 2022, 09:38 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,832 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Bob, It has been pointed out to me that those aren't necessarily jack pads but rather attach points used during assembly. Just as long as your under the long your OK. (IMG:style_emoticons/default/beerchug.gif) I agree, If you can lift it at the longs, you are good. A set of 4 hockey pucks with a grove cut down the middle to accept the pinch welds would be great. I've never used a quickjack so I don't know what works best. It never hurts to use a 5th point of contact, like a deadman or a tall jack stand, to help guard against a weight shift if you are dropping an engine. tires will do in a pinch. |
bkrantz 914 on Quickjack 7000TLX--Fail! Dec 12 2022, 08:39 PM
bkrantz But the rear jack point is far forward of the lift... Dec 12 2022, 08:41 PM
bkrantz The front jack point and pad look OK.
But I could... Dec 12 2022, 08:42 PM
bkrantz I then swapped the Quickjacks from side to side, s... Dec 12 2022, 08:43 PM
bkrantz Again, the front lift pad is OK. Dec 12 2022, 08:44 PM
bkrantz And the rear lift pad, as far forward as possible,... Dec 12 2022, 08:45 PM
bkrantz But as the car lifts, and the suspension drops, th... Dec 12 2022, 08:49 PM
Robarabian You should have the pinch weld rubber pads. You ca... Dec 12 2022, 09:37 PM
Freezin 914 I have the QJ 5000, it is tight by the wheels, but... Dec 12 2022, 10:05 PM
914sgofast2 I have the 5000 model too and it is finicky to get... Dec 12 2022, 10:21 PM
bandjoey Do not try to flip the lift sideways. As it lifts... Dec 12 2022, 10:32 PM
SirAndy You can use the engine crossbar ok.
Only if it is... Dec 12 2022, 10:53 PM
peteinjp
Only if it i... Dec 13 2022, 05:18 AM
mlindner On both front and rear I use a larger board over t... Dec 13 2022, 05:26 AM
Retroracer Seconded (thirded?) for NOT putting any significan... Dec 13 2022, 08:22 AM
NARP74 Well smack me in the head with a salmon. I have b... Dec 13 2022, 09:49 AM
Well smack me in the head with a salmon. I have ... Dec 13 2022, 10:45 AM
NARP74
Well smack me in the head with a salmon. I have... Dec 13 2022, 11:00 AM
vitamin914
[quote name='mepstein' post='3045030' date='Dec 1... Dec 13 2022, 02:07 PM
drem914
Well smack me in the head with a salmon. I have ... Dec 13 2022, 02:18 PM
DaveB I use two of the pads interlocked. That allows the... Dec 13 2022, 11:28 AM
PanelBilly I use a 2x6 on each side to make it longer. Dec 13 2022, 01:56 PM
FlacaProductions I'm using an EZCarLift on the donuts without i... Dec 13 2022, 02:24 PM
wonkipop i must admit i use the longs when i have the car o... Dec 13 2022, 03:04 PM
SirAndy ... dunno?
The factory always used all 4 donuts t... Dec 13 2022, 04:13 PM
wonkipop
[quote name='wonkipop' post='3045076' date='Dec 1... Dec 13 2022, 04:37 PM
NARP74 The donuts were younger back then! Dec 13 2022, 03:21 PM
RKramden Cut a slot in a short piece of 4x4 it straddle the... Dec 13 2022, 05:03 PM
Cut a slot in a short piece of 4x4 it straddle th... Dec 13 2022, 07:50 PM
RKramden
Cut a slot in a short piece of 4x4 it straddle t... Dec 14 2022, 11:03 AM
The Double S I have the 7000SLX which I had to use sideways for... Dec 13 2022, 05:59 PM
bkrantz Thanks, everyone.
I agree about the risks of usin... Dec 13 2022, 08:05 PM
PatMc I have a portable mid rise scissor lift, and find ... Dec 14 2022, 06:57 AM
Front yard mechanic I have made up my mind not to buy a quick lift wit... Dec 14 2022, 07:34 AM
Olympic 914
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 07:45 AM
The Double S
I have made up my mind not to buy a quick lift w... Dec 14 2022, 10:18 AM
VaccaRabite
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 07:51 AM
Jim C
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 07:57 AM
PatMc
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 11:37 AM
I have made up my mind not to buy a quick lift w... Dec 14 2022, 11:55 AM
Front yard mechanic
[quote name='PatMc' post='3045242' date='Dec 14 2... Dec 14 2022, 08:21 PM
PatMc
[quote name='PatMc' post='3045242' date='Dec 14 2... Dec 15 2022, 01:29 AM
iankarr
I have made up my mind not to buy a quick lift wi... Dec 14 2022, 09:11 PM
DaveB
I have made up my mind not to buy a quick lift wi... Dec 15 2022, 09:04 AM
dax1969 Have the new 5000 TL wiht increased lift height. ... Dec 14 2022, 08:06 AM
iankarr Amazing work and congrats on entering this next ph... Dec 14 2022, 10:51 AM
burton73 https://garags.com/product/maxjax-m6k-porta...mp;u... Dec 14 2022, 08:56 PM
vitamin914
[url=https://garags.com/product/maxjax-m6k-portab... Dec 15 2022, 06:34 AM
burton73 IS SHIPPING FREE?
Yes, shipping is free in United... Dec 14 2022, 08:59 PM
mepstein I’m sure it’s a scam site. Lots of them around... Dec 15 2022, 07:55 AM
NARP74 Been researching 4 post lifts for storage and work... Dec 15 2022, 09:45 AM
RKramden I beleive these jacks and stackers might require a... Dec 15 2022, 09:50 AM
vitamin914
I beleive these jacks and stackers might require ... Dec 15 2022, 11:29 AM
dhuckabay Have a two post Chinese that I got off eBay. Seem... Dec 15 2022, 09:51 AM
mepstein In my workshop, i have a two post maxjax. I was ab... Dec 15 2022, 01:57 PM
vitamin914 Another way to look for scam websites is to check ... Dec 15 2022, 03:25 PM
peteinjp One other things to keep in find is that we are
of... Dec 16 2022, 06:10 AM![]() ![]() |
Lo-Fi Version | Time is now: 26th July 2026 - 12:24 AM |
